Question about Kenmore 78812 / 78814 / 78819 Gas Kitchen Range
75214101 baking is not coming out correctly. Temps go from 350 - 400 / replaced the thermostat still having the same issue. So dicouraged, I once was a avid baker.. NOW I hate this stove.
  • momgleas Jun 27, 2009
    so how many cakes do you have to bake to know you are at the right temp? I will never buy another Kenmore product
  • 867 Answers
I have never seen a stove that actually heats the oven to what the dial says. they are all hotter or colder, so best is to add or subtract 50 * according to your problem, like under cooking or over cooking. find the sweet spot
Posted on Jun 27, 2009
Oven is too hot. How do I adjust the temp.
Something has to be wrong with the thermostat that controls internal temps. Replace it
Nov 18, 2015 | Kitchen Ranges
Heat issue
Chances are your coolant level is low or an air pocket is present in the cooling system.
Nov 08, 2015 | 2000 Jeep Grand Cherokee
Is this a common problem?
THATS BECAUSE IN ORDER TO CONTROL BOTH TEMPS IT USES THE HELP FROM THE FREEZER AND FRIDGE THERMISTORS AND THE COLD CONTROL THERMOSTAT. A BAD DOOR SEAL OR SEALS CAN ALSO CAUSE SOMEWHAT SAME ISSUE? ALSO NEED TO CHECK UR DAMPER CONTROL MAKE SURE ITS WORKING CORRECTLY.
Jul 29, 2014 | Hotpoint Refrigerators
My Kennmore 790.95312300 will not heat up on Bake
If the element tests good, the clock / control is most likely the problem and will need replacing.
Oct 20, 2017 | Kenmore Kitchen Ranges
2000 ford taurus heater not working correctly
Thermostat issue. Replace it. Not properly regulating coolant temps - affects heater temps.
Sep 05, 2017 | 2000 Ford Taurus
The baking element failed in my JBS55. I ordered
hello,
I can not better explain it as described in the link I send you below.
I hope this helps, Dik
Oven Thermostats Help Advice Fitting
Feb 04, 2018 | GE JBS55 Electric Kitchen Range
Ruud achiever 90 plus won`t start
Check the data information on the unit there should be a troubleshooting guide that tells you what the two lights blinking once means. hope this helps.good luck. normally found with schematic
Feb 05, 2009 | Ruud UBHC Air Conditioner
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Uneven heating in our Whirlpool range
on bake setting only your bake element is on broil element comes on for preheat only naturally the top part of your oven is hotter heat rises take the temp in the center of oven with a good thermometer
those cheap ones are a guide only dont swear by them
Dec 06, 2007 | Kitchen Ranges
Trouble baking
Sounds like it's running too hot. Check temps. May have a stuck relay on board. Run oven and check to see if bake element is cycling off when it reaches temps. It should stop glowing within
15 minutes from start. If it doesn't you need a relay board most likely.
Nov 04, 2007 | Jenn-Air JJW8330D Electric Single Oven
Kenmore 78812 / 78814 / 78819 Gas Kitchen Range Logo
166 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
