It says that the paper is pending then printing but nothing seems to come out. It has a full color ink cartridge, full paper, but nothing works. It still turns on and sometimes flashes.
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
SOURCE: HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the
printing problem..
# Hold the cartridge upside down, with the
bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the
cartridge on the bottom (where the ink comes out). Wipe the printhead
horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure
the ink is flowing.
# Next, look inside the printer and locate the
carrier that holds ink cartridges. Caution: Make sure the cartridges are not
installed at this point.
1. Look for a shiny piece of metal underneath the
contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and
wipe along the bottom of the shiny metal piece. Note: You may need more than
one swab.
# Reinstall the cartridges, making sure you snap
them correctly into the printer.
Hope this help. Please
Rate My Response! Thanks!
SOURCE: My printer is not printing
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
SOURCE: HP K8600 - Why can't I print with black ink only
IT WORKS!!!! GOD BLESS YOU MCGYVER GEEK!!!! YOU SHOULD SELL THAT SOLUTION FOR 10 BUCKS. YOU'D BE RICHER THAN HP!
