MY HP 6735S LAPTOP ONCE POWER ON SHOWS THE FOLLWING: (1) POWER LIGHT STAYS ON; (2) HDD LIGHT BLINKS AMBER CONSTANLY; (3) WIFI LIGHT STAY STEADY ( same thing happen when i remove memory; battery and hdddrive ); what might cause this.
anything on screen? tried an external vga monitor? and other flashing sequences of lights? can you get into bios?anything on screen? tried an external vga monitor? and other flashing sequences of lights? can you get into bios?
Hi Anoop PS, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?Hi Anoop PS, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
This means that HDD is faulty . You can confirm it by re fixing the hard drive . Shutdown computer > Remove HDD > wait 1 min and Insert it > Start computer . If you get any of the below status Steady Amber (Orange Led) = Drive is Faulty Amber Blinking = Hdd rebuilding
If orange led blinks , it means hdd is in rebuilding state. Wait for sometime and check if it come online . On the other hand (Steady Amber) its time to replace HDD
Probably your waste ink counter. Should be cleaned or replaced before resetting
but usually you can get away with resetting once. 1. Start with printer
OFF 2. Hold down RESUME and then hold down POWER 3. Release RESUME 4.
press RESUME twice, then release POWER 5. let green light blink until
printhead has finished moving. 6. Select functions below with RESUME, execute
with POWER
0 presses - green light - Test Print 1 press - orange light - EEPROM info print 2 presses - green light -
EEPROM initialise 3 presses - orange light - reset waste ink counter.
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
1. remove all ext peripherals 2. remove battery 3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop) 4. try any other wall socket check if ac adapter will led stay on 5. if ac adapter stayed on then connect to laptop (without the batter) 6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage. 7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber) 8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink. 9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
