Question about Canon imageCLASS D780 All-In-One Laser Printer
Copies are blank
It seems there may be an issue with the scanner/lamp as it looks dimmer than I recall (but i never really paid attention before). All copies run normally but nothing prints. A blank page just comes out.
  • JeremyP Nov 06, 2007
    whats factory reset? how do I do this. And what do I check on the scanner lamp?
    Problem Solver:
  • 10 Answers
Posted on Nov 06, 2007
I am now getting blank copies when copying only from d-copia 3514mf olivette.thescanner lamp is coming on and the scanner moves
Can you check the connection to the CCD on the scanner lamp? The doc feeder comes off by lifting it upwards whilst wiggling it. Then unscrew the lid. Make sure it is unplugged when you are doing this. There are high voltages within the scanner lamp unit.
Aug 18, 2016 | Olivetti Office Equipment & Supplies
Blank copies from copier
You don't say what model your fax is.
In general. If when copying you get a Full BLACK page printed then the scanner lamp is not lit. As no light is reflected into the image scanner, it interprets this as BLACK information so therefore only black is printed. Look into the ADF while the document is being scanned and I bet you will see no green light at all. A new Contact image sensor should cure it.
Jan 13, 2014 | Canon Duplex Automatic Document Feeder
When we make copies they come out really, really dark. We have the setting as light as it will go. How can we resolve this?
  • try this when a dark image of original.
  • clean the scanner cavity,lenses,mirrors,scaner lamp reflector
  • adjust/increase scaning lamp voltage (on lamp regulater pcb)
  • clean/adjust hight of charging corona wire
  • adjust bais voltage in servce mode (add function then both key2 and 8 saimantaniously then add funtion)
  • adjust/replace cleaning blade
  • replace scanner lamp
  • Try this when zed black copy came out
  • check scanner lamp is working
  • check developing unit connection and contacts
  • check drum earthing contact
Jan 06, 2011 | Canon NP 6230 Copier
Out put is looking dimmer, picture seems to havefaded
Perhaps your lamp is on the way out? they do get dimmer as they age..
Jan 31, 2010 | HP Projector Lamp for vp6110, vp6120
Xerox M15: Blank copies
There is a problem with the Laser Unit
need to replace the LASER nit or need to open and clean the unit will solve the issue
Jan 22, 2010 | Xerox WorkCentre M15 All-In-One Laser...
I just paid a tech to come out because the printer stopped printing (the pages were coming out blank) I purchased new toner; but that didn't fix the problem. The Tech came out and said he just had to...
I suggest you remove the toner cartridge, take it outside and holding it away from you shake it back and forth a few times. Reinstall it and try printing.
Sep 21, 2009 | Office Equipment & Supplies
Canon NP6412 Blank Copies
If copies are totally blank then it most likely is not the drum. It is transfer to the drum. A charge wire is most likely the cause of these type symptoms. Not easy to do if you never have before. Exposure lamps being bad give a solid black copy symptom so I am pretty sure thats not it either. You have a charge corona inside that is probably what your issue is. If you know someone who is a tech they might restring it for you as a favor or take the unit to a local dealer to see how much they would charge to restring.
Hope that helps
Mar 29, 2009 | Canon NP 6551 Black and White Copier
E212 message
Error code means something is wrong with the scanner of the copier, it could be the lens is not moving or the scanner is not finding HP. Also, are you getting blank copies? If so you have a blown scanning lamp.
Jan 12, 2009 | Canon NP 6551 Black and White Copier
Canon np6050
Dose the scanning lamp come "ON" when you make a copy. If it will not come "ON" your scanning Lamp is blown and needs to be replaced. When the scanner lamp blows you will get blank copies..
Dec 18, 2008 | Canon NP 6050 Copier
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
Canon imageCLASS D780 All-In-One Laser Printer Logo
147 people viewed this question
old marine
old marine
