These motors will stick sometimes during periods of not being used. With the power turned off to the the dishwasher, remove the front lower grille. There are usuallly 2 screws on each side of the panel. Looking under the D/W your will see the motor and pump assembly. If you feel around you should be able to feel the motor's cooling fan. Simply rock the fan back and forth and the motor/pump should become unstuck.
Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
Hi, Have your freind check and see if the water supply line under the sink has been turned on. The hum you are hearing could be the inlet valve. Please let me know if this has been helpfull or if I can assist you further.
I have a portable that had the same problem. I called a repairman and he turned a fan blade on the motor. Mine is located on the right side about 12" in. It gets hung up when it is run often enough. If your problem is the same is mine all you have to do is turn the blade and it works like a charm. Hope this helps.
Your problem is: there isnt any water going to your dishwasher and its just making a humming noise when you turn it on
The most likely culprit is the solenoid valve. It is a simple on/off valve under the d/w on the left. Depending on make and model I might remove the d/w from the cabinet to facilitate installation. Don't forget to turn off the water first.
Feel free contact me again! Please give me a rating here at fixya.com before you sign off Thank you, Harvey your Master Plumber
If the water seems to be flowing in slow, I would turn off your water
supply to your dishwasher, then disconnect your water line to your
inlet water valve, then check the screen on the inlet water valve, its
most likely clogged.
