The master security code will be the same as your lock code if you have changed it from the factory pre-set code. For Nokia the default code is either 123456 or 12345. If those do not work, then the only other default codes' are as follows, all 0's,or all 1's, or all 9's.
start your computer, continously pressong, f2 and del key, go to bios set up,, set default settings, save it, then restart your computer, by pressing ctrl+alt+del
If the thermostat is not over shooting the temperature than don't worry about it.
These thermostats are very sensitive and will turn the heat back on even before the degrees drop on the display. Often they will shut down before the display changes also. You can change the sensitivity of the thermpstat if you read the directions and change the cycles per hour to a less number. There is an installers program in there that you need to push a combiunation of buttons to get too. The instructions tell you how to do that also.
Hopefully you did not throw away the instruction manual for your t-stat.. :-)
