Question about Mi T M #WP-3400-4MRB 3400PSI Pressure Washer
Mi-T-M 3000 would not start and now engine does
Mi-T-M 3000 won't start up. It has gas and oil, just hasn't been run in a while. I'm an experienced user of power washers so I know how to start the thing. Any ideas?
  • 174 Answers
"just hasn't been run in a while"
The first thing to try is replacing the gas
Posted on Jun 28, 2009
Suzuki 20087 2.4 eng,ude 1 qt in 3000 mi can you use a higher viscosity oil to slow it up
no Suzuki stated (we are usa, )
no car stated, name of car, full.
no country,
2.4L (j24B engine? my guess) 4cylinder gas water cooled.!?
what is UDE? (google returns 0 hits) typo?
answer, sure try 10w-40 in it.
is the PCV valve nice and clean,
how many miles on engine,??????????????????????
see water in the engine oil?> (milk-chocolate ) (cars)
Mar 05, 2017 | Suzuki Cars & Trucks
Fuel and oil lights flicker at 3000 rpm and up
Check wiring to console, especially the ground.
Mar 30, 2014 | 1984 kawasaki Z 550 F
Starts but won t keep running
Probably not. Once the oil passages inside the engine get plugged up the block has to be hot-tanked to get them cleaned out. Thats after the engine is disassembled.
You can try an engine flush or two, but I would not expect much.
You may not be getting power to the fuel pump if oil pressure is low.
Jul 14, 2013 | Chrysler 300M Cars & Trucks
Water in my gas tank
dont run the engine...remove the oil pan plug and drain the oil as long as the car hasn't rain i think your ok in terms of it not being in your engine and just to be cautious buy the cheapest oil you can find along with good oil put a little bit of cheep oil on and drain it put the rest of it in run it and then drain the oil and put the good oil...
Performance Chip
May 23, 2012 | 1996 Jeep Grand Cherokee
I have a major oil leak from the front of my car, the car will turn over and start but when i press gas peddle it stalls, there is oil in it now. oil presure gauge has been dropping when the car slows to a...
Check the oil pressure switch as it's next to the oil filter. You describe a car that hasn't had the oil changed often enough as the dirty oil is eating things up The switch the oil filter and the engine. The oil filter can leak too. These cars seldom leak if the oils is changed regularly (4 times a years or at least every 5000 miles.
Jun 24, 2011 | 1993 Oldsmobile Cutlass Supreme
We got a saturn vue 2003 2 years ago it had 60x mi on it now it's got 84x we change oil every 3000 mi and last year we took it to the dealership for service, but i want to know what other services should i...
Keep the serpintine belt, oil/oil filter, air filter, gas filter and transmission fluid/filter changed regularly. At 84k, check the brakes (front and back). I would look at changing the spark plugs as well. If it is running good, you want to keep it that way...good luck
Feb 07, 2011 | 2003 Saturn VUE
Can i run plus gas in my washer
I'm not sure what you mean.
I think you are asking if your power washer needs oil mixed with the gas.
Does your machine have a oil reservoir below the engine?
If there is a place to put engine oil, then your engine runs on ordinary gasoline.
The pump oil is SAE20 or SAE30 non-detergent motor oil > oil comes up half way inside box.
The engine oil is 10W30 motor oil > oil comes up bit more than half way on dipstick
Oct 21, 2010 | Northstar Pressure Washer 3000 PSI
Where i have to store in the winter? . how many offen y have to change the oil pump and engine?
Heat you machine and take out the oil, then you can store it in a safe and dry place.Oil pumps and engine can stand as long as you care it.
So if your machine start with some problems try to fix it in a professional way.
Oct 13, 2010 | Mi T M Cw30044mgv 3000 Psi 11hp Pressure...
How often should i change tranny fluid, 3000 mi, 5000 mi, ?? I'm running Harley oil now do U recommend synthetic oils.
If you're running Harley oil, you're running either semi-synthetic or full synthetic. You bike came with H-D Syn3 20W50 fully synthetic oil in the transmission. They use the Syn3 in the engine, transmission, and primary now. You can use whatever you like. Amsoil, Royal Purple, and Mobil make oils that are suitable for this use but you'll have to check their website to determine which one they recommend.
Jun 29, 2010 | 2000 Harley Davidson FLSTC Heritage...
Mi T M #WP-3400-4MRB 3400PSI Pressure Washer Logo
172 people viewed this question
Top Mi T M Garden Experts
JOHN LAPIER
Gregory Ferreira
Are you a Mi T M Garden Expert? Answer questions, earn points and help others
