Question about Maytag MAT13MN Top Load Washer
Maytag Washer Getting stuckon wash cycle
My top-load Maytag Washer (4 years old?) recently is getting stuck in the wash cycle in the normal mode. The delicate cycle works fine, start to finish. When in normal mode, it fills, begins washing, and won't stop washing (with agitate) until you manually move the knob to the drain/rinse section. Could this be a problem with the timer?
  • alexenjen May 19, 2008
    Maytag HAV4657EWW
    I have a 3 year old washer that's constantly getting stuck in rinse mode. I start the wash, water fills, then water drains - it get's stuck in this cycle of water filling and draining.
    Problem Solver:
  • 18 Answers
The possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Posted on Dec 27, 2008
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
Won't progress beyond wash cycle -- start light is flashing. Cannot switch from "normal" to delicate or any other choice. Maytag Neptune TL FAV6800AW
So I understand the issue. Does the wash cycle start up? By that I mean if you release the washer top from the base do the tumblers turn once the water fill cycle is complete?
If you don't have the FAV6800A/FAV9800A Service Manual (you can't get it on line anymore) see this post Clutch Fix I describe how to release the washer top from the base to observe the wash basket. Don't raise during the water fill cycle wait till that completes.
Does the key pad beep as you press the other cycle select key pads?
This could be a Control Board issue...........Rich
Oct 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Recently our Maytag Performa washer has started
The transmission might be going bad.
Nov 02, 2009 | Washing Machines
Leaks on Delicate but not on Normal.
Appears to have been the drain holes below the rubber drum flange. My wife cleaned in there for the first time after our speaking to a lowes sales person who owns one as well. When I monitored the next "delicate" load with the front panel off and after cleaning, there was no sign of water anywhere. Hope this was the solution. My wife also mentioned the loads (on delicate) came out damper than the norm but this time it was much drier. Wonder if delicate cycle may fill the washer higher than the normal cycle.
As a footnote we mentioned an occasional musty smell would occur and the same sales person said to not only leave the front door ajar but also open the soap drawer. When I checked the service manual I noticed the unit has a vent hose which vents into the soap drawer. All makes sense when you consider a front load is much tighter sealed than a top load.
Jun 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Whirlpool washer sometimes stops after the wash cycle
Sounds like the timer has given up. I bet if you just barely turn it, it will continue.
It's a common problem with timers like this.
Replace it.
Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Maytag MAT13MN Top Load Washer Logo
537 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
