Question about Haier HLP21E Top Load Washer
Need a replacement lid for the HLP21E. The little plastic piece on the lid that pushes up the little plastic piece in the washer to make it function broke. There is nothing wrong w/ the machine except that it won't work without something pressing up the little piece of plastic. Is there a place I can order a replacement lid?
    New Friend:
  • 118 Answers
Did you call Haier? They have replacement parts.
Posted on Jul 22, 2009
How do i locate my washer safety lid switch on model haier hlp23e?
slide the tape covered screw driver or plastic spakle knife to pop off the lid, from the two clips in the front. Once that opens pop off the back and under the main washer deliver, you can see the door closed switch.
Sep 23, 2015 | Haier HLP21E Top Load Washer
Washer fills with water. agitates, does'nt finish cycle. still full of water.
The most common reason for this problem is the Lid Switch. If the lid is not closed, washer will not go into extract (drain) & then spin cycles. Check the lid to see if the plastic piece that pushes the switch down is broken off. You can simulate "Lid Down" condition by depressing switch with a screwdriver. It's located on the right side of the wash drum / tub. There is an oval slot there & you should hear & feel a click when pressed down. Look directly above that slot on the lid bottom for the plastic piece that is commonly broken off.
If it is, you can apply a temporary fix by wedging something in the slot to depress switch while you order a replacement part.
*****WARNING*****
Operating washer with this interlock defeated can cause severe injury!
Washer will continue to spin with the lid up!
You should use this technique for troubleshooting purposes ONLY!
Please reply if this is NOT your problem and I'll post other causes & solutions for you.
Sep 16, 2010 | Whirlpool Washing Machines
I moved and it seems that a plastic piece came loose inside the machine and was laying on the bottom/ It is a rectangular piece and i cannot seem to find the right placement of it. Can you help?
Not a lint filter is it with a mesh bag attached? It may slot into the side of the bowl towards the top somewhere.
If thats not it perhaps you could describe it a little more.
May 21, 2010 | Haier HLP21E Top Load Washer
Maytag washer #A882 Washer fills, but will not agitate. Can hear timer run and after numerous tries of unplugging and slamming the lid, it agitates. My husband doesn't think it's the lid switch. Could it...
Open the lid and in the middle pull the cap off the top off the agitator.
Then remove the little plastic piece, and you should see a 1/2 nut and some little plastic teeth that when the unit is running it locks into those.
Verify by turning with your hand that they are not striped out, If they are then you will need to replace those. If its not agitating it will be more Technical to diagnose.
Also make sure the screw is tight.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 09, 2009 | Maytag Washing Machines
Same problem: Lid Open Alarm
You will need to replace the part on the lid. This piece pushes on the lid switch letting the machine know the lid is closed. You can by pass this until you are able to get the piece by pushing a screw driver into the hole where the part from the lid went. Be sure not to push it in to hard, if you do you will have to replace the switch also. Be sure to replace the part from lid because this is a safety switch to keep hands and arms out of the machine while it's running.
Please rate solution
Sep 07, 2009 | LG WFT1071TP Top Load Washer
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Kenmore series 80 washer won't spin or drain but will agitate.
you will need to replace the plastic piece that triggers your lid switch hopefully you havent damaged your lid switch (probably not) the are easy to replace and very inexpensive less than ten dollars usually you can purchase one of them from your local Sears or just about any appliance store they just push in to clip you dont even need any tools thanks hope this helps you
Dec 31, 2008 | Washing Machines
Oasis elite washer lid locking mechanism broken
go to repairclinic.com to find the part. Have the make and model ready, and you have a good chance of finding the part there.
Mar 02, 2008 | Washing Machines
Malber p21 spin
the lid switch must be broken if you know how to use an screw driver you can fix it remove the lid witch and replace with a new one, remember to unplug the machine frome the wall...good luck
Aug 04, 2006 | Malber P21 Front Load Washer
Haier HLP21E Top Load Washer Logo
287 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
