Question about Homelite Garden
Homelite xs 135 runs 10-15 min then stops. have to reprime and it runs 10-15 min.
  • 1,041 Answers
Either the gas mixture is not quite right or the gas cap is slightly clogged.
If you don't have enough oil in the gas, this may cause it to overheat.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
  • Jim Parker
    Jim Parker Jul 01, 2009
    Did this solution solve the problem?
    Jim
Have a homelite bandit sx-135 line trimmer and i have replaced the fuel lines and the bulb but now it will start but it will not get above idle speed every time i press the accelerator it will stop. ive...
I would recommend a $20 jewelry cleaner from a tool shop. it comes in handy for many things. it will help get the debris out of the small check valves in the carburetor. That is the issue with a machine stalling out or not running above idle when you have fixed air leaks like the fuel line.
You can get parts and supplies at stores like www.arcolawn.com
Feb 11, 2011 | Homelite Garden
Oil & Gas Mixture
if you are using sthil oil the mix is 50:1
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Restringing a homelite bandit trimmer
What is the correct size of the nylon cutting material - on my homelite bandit SX-135 trimmer ?
Thanks, Bill.
Apr 30, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
My homelite chain saw will only run after I prime the fuel once gas runs out engine stops running but reprime fuel the saw will run until fuel runs out any suggestions
Did you replace the fuel lines? If the filtered hose feeds the primer that is exactly what happens. Your fuel system should be similar to this.
Fuel Line Replacement
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH Lou
Nov 30, 2009 | Homelite Garden
Need manual for homelite sx-135 weedeater
http://www.homelite.com/service_support/order_parts
Feb 14, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Garden Logo
145 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
