There are more than reason: first check the fan in the upper part of the freezer (you have to unscrew 3 bolts of the cover),second check the freezer door sealing,third is to check that the cooling tubes inside the freezer are cold enough without heavy snow (you have to unscrew about 6 bolts of the cover),Heavy snow reduces cooling and it means that the timer is not working or the heater is not working.I hope to help you in reform
SOURCE: Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
SOURCE: Fridge not getting any air, freezer is working
I have a Kenmore w/ freezer on bottom. The top vent in the fridge is ducted to the freezer and is supposed to blow air. Mine was not.
I removed all the frozen goods and took off the back panel (inside to unit) which had a little ice on it. Underneath the panel was a solid wall of ice......including the motor which is supposed to blow air up to the 'fridge. I'd bet a beer that is your problem as well.
The ice seized motor will not be harmed because it is resistance loaded.
The best part is with a blow dryer and some elbow grease...the fix is free! I hope it helps.
SOURCE: Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
