Question about Kenmore Dryers
If clothes are wet then no heat. if clothes kinda dry then heat at first then no heat
  • 97 Answers
Hello Friend, If the burner on your gas dryer is igniting the first few times producing heat in the early part of the drying cycle and then Doesn't ignite the remainder of your drying cycle, It's pretty safe to say that you need to replace the valve coils. Here's general information pertaining to the replacement of your valve coils: Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks!
Posted on Jun 27, 2009
  • MrQuickFixit Jun 27, 2009
    You know what, You didn't specify if it was a gas dryer or electric dryer. So, the information below is what you'll need if it's an electric dryer.You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Hope this has helped you. Thanks, Tim.
Kenmore model 90 dryer electric will dry the clothes takes a long time. Leaves the floor surrounding the dryer damp actually wet just not puddled
Are the clothes wet AND hot? If so - check the exhaust / vent hose for kinks or obstructions. That includes the cap / flap on the outside of the house.
If the clothes are wet AND cold, then the electric heating element isn't heating likely due to a broken or poor electrical connection, burned out heating element, defective thermostat, etc..
Jul 14, 2015 | Kenmore Dryers
Clothes don't dry or get warm
Ether a bad heating element,or an obstructed discharge vent. The bad element will prevent heat production, a blocked discharge will not allow humidity to escape, resulting in wet clothes. Hope this helps.
Sep 11, 2013 | Dryers
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
My dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Jul 28, 2010 | Whirlpool LER4634J Electric Dryer
Everything works but no heat to drying clothes. Gas is turned on and every so often the clothes are kinda warm, but minimum 2 dry cycles to get stuff dry
i would check my exhaust vent here, make sure you have good airflow
let it stand for a while, and start it up let run
are you getting any heat, put you hand tword the back
if you getting dry by very low heat, i would suspect you gas coils, two bullets on the top of the gas valve
Oct 13, 2009 | Maytag Neptune MDG5500AW Gas Dryer
NO HEAT WHEN CLOTHES ARE ADDED
Check to see if vent hose is not restricted. If it goes up inside wall, it could have lint clogging it. Most dryers regulate heat with air flow. Wet clothes can restrict flow even more if vent is clogged or pinched. Air flow is crucial to heat cycle. If the vent is resrticted, heat will rise quickly, but not cool down fast enough to allow heat thermostat to cool down and turn on heating element again. It may seem hot inside dryer but if no air flow it will increase dry time or not dry them at all before timer shuts off. If vent goes up inside wall, buy a small chimney brush and try cleaning out vent from attic if you can.
Jul 24, 2009 | Maytag MED5800TW Electric Dryer
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Dryers Logo
141 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
