Gigabyte GA-8SIMLNF Rev 1 motherboard specs + help
I have a Gigabyte GA-8SIMLNF Rev 1 motherboard with a intel pentium 4 processor at 2.53Ghz. I want to make a computer out of it,and since I can't afford parts I was wondering if I can just swap this motherboard for the one in my current HP Bro BA410. Of course it would require the right power supply. I've looked up that the power supply in my Brio has the following specs:
0950-3982 Part is in stock.
Switchable power supply (Delta DSP-120EB B) - 100-240VAC input, 45-66Hz - 5 DC outputs, 120 watts
according to the HP website. So I need to know what power supply my Gigabyte motherboard would need and whether its compatible with this power supply and whether I can just do a simple swap.
  • edmund_willi Jul 04, 2009
    Ok,thank you.
    But I'm not sure if this has enough of the right sort of power connectors. I have and IDE hard drive- I'm not sure what sort of power connector this takes, but the one I had in it, and works perfectly, I need three of them, because my two CD drives take the same sort.
    Also, I don't know if that's the right wattage, but that's because I have no idea how to tell what's the right wattage, does it depend on the motherboard, the processor, or all the parts I have plugged in, of so does that mean if I plug more things in some things won't work? And does it mean that if I have a PSU with a too high voltage I'll fry everything? I really don't know how to tell what wattage I need.
  • 16 Answers
The following power supply unit (PSU) should work just right, however, it will not fit in a company branded case such as HP, Compaq, Gateway, Dell, etc. sine they all use proprietary parts and cases:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817339019
Posted on Jul 03, 2009
GA-8SIMLNF rev 1.1 driver
http://www.gigabyte.com/products/product-page.aspx?pid=1335#dl
Jul 11, 2014 | Gigabyte GA-8SIML Motherboard
Does the GA-8I945P-G supports the Core2duo Processor?
No since this is a older mobo the manufactre only recomndes you use Pentium D, Pentium 4 HT, or Celeron D. many people have tried this and have had alot of problems and little success.
May 04, 2011 | Intel Gigabyte GA-8I945P-G Dual-Core CPU...
Can the motherboard GA-8S661FXM-775 support AMD Athlon X2 CPU?
This motherboard only support this type of processor , Supports LGA775 Intel® Pentium® 4 / Pentium® D* processor FSB800 with HT technology.
For the complete details about this motherboard check this link, just click HERE.
Dec 17, 2010 | Gigabyte Computers & Internet
What cpu is compatible with motherboard GIGABYTE GA-965P-DS3
Go to http://www.gigabyte.com/support-downloads/download-center.aspx?kw=GA-965P-DS3
and click on revision 1.0 - 3.3 as there may be additional CPUs supported in Rev 3.3 vs 1.0, you have to determine what specific Revision you have.
Dec 01, 2010 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
Have more questions concerning this, or comments, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
My motherboard (GA-8VM800PMD-775-RH) has a Intel Pentium 4 installed. Is that a Pentium Quad or what?
Sorry to say that the motherboard only supports dual core processors. Click on the link below for full specifications on the motherboard. Link below >>>>>
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2333
Kind regards and thanks for using FixYa!!
Feb 25, 2010 | Gigabyte Computers & Internet
My AMD x4 processor problem with gigabyte motheraboard
please load windows xp 64 bit . it will work well.
also check the temperature of motherboard and processor in bios
if temperature high use good heat sink and cpu fan .
Sep 19, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I want to find out if this motherboard is combatible with ddr2 memory and if i can upgrade the processor to dual core
Type: Dual Channel DDR 400/333 Mhz
Max capacity: 4 GB
DIMM slots: 4
Use Socket 775 processors:
Supports LGA775 Intel® 90nm Pentium® 4 processor FSB800 with HT technology
Apr 15, 2009 | Gigabyte GA-8I915P Duo Pro Motherboard
Will my motherboard support a Core 2 Duo processor: GA-8S649MF (Gigabyte Motherboard)
Every system needs a rock-solid foundation, and that's just what you get with this Gigabyte GA-8S649MF motherboard. It features Socket 775 compatibility and support for Intel Pentium 4 or Pentium Dual-Core processors with 800 MHz front side bus speeds. Two DIMM slots support up to 2 GB of DDR400 system memory.
Dec 21, 2008 | Intel Motherboard
Computers & Internet Logo
3,521 people viewed this question
Alun Cox
David Payne
David Payne
