Who makes this K7VTA3 MO/BO - Computers & Internet
  • 672 Answers
ESC is the MOBO manufacturer, via makes the chip. Here's link to review of MOBO http://active-hardware.com/english/reviews/mainboard/k7vta3.htm
Posted on Jun 27, 2009
No signal going to monitor
1-Check out your video card to make sure it is properly seated in mo bo. 2- If video is from on board chip then add a video card to see if that works - if so your mo bo video is done.
Sep 15, 2017 | The Computers & Internet
Will not go into bois, will not bootup. I've already checked drives, memory. pci and tried another power supply.
Mo bo is DEAD. Unless you can spot a bad cap(s) somewhere just replace it wit identical unit to keep things easy.
If you replace mo bo with one other than original, depending on OS you have, you may or may not have to reload completely.
Mar 14, 2016 | Computers & Internet
I have a msi board that is not beeping during bios,what could be the problem ?T
If the motherboard is not posting there could be something wrong with your bios. OR, if you have a problem with a peripheral that might also cause the mo bo to not boot up - in the latter case remove all items except the memory and attempt to post. If it does add items one by one until you come across the epripheral that will not allow the mo bo to boot.
If no post with all items removed then the mo bo is definitely suspect. U can try using a new bios chip but that is not a guarantee that it will work.
Apr 10, 2015 | MSI Computers & Internet
Sound problem
If audio circuits on mo bo do not work only thing you can do is continue to use separate sound card or replace the mo bo with a new one.
Mar 19, 2015 | Computers & Internet
Stops after 3 seconds, no video, no bips, fans running, power led on,optical mouse led
Mo bo has gone to mo bo heaven. It is not posting so something is definitely wrong with the board itself. Maybe the bios chip has gone south.
Mar 11, 2015 | ASUS M2N68-AM SE2 Motherboard
My hp 7060n won't pwr on. I checked the ps it test
I don't think you know what you are doing. No computer will boot without memory! And no mo bo will work without the 4 pin connector being attached to mo bo along with the 20/24 pin mo bo connector..
Listen, keep it simple and just plug in another known working ps to see if unit works. If it still does not work, then your issue could be corrupt bios, bad hard drive, corrupt OS, bogus peripheral, bad memory.
Sep 16, 2017 | Computers & Internet
Hi, i have a DFI INFINITY-NF-ULTRA2-M2 MO-BO and i have 2 0f the 4 mem slots filled. I am unsure of the total available exspansion capabilities of the mo-bo. I have moved several times since building this...
If 2 memory banks are filled totalling 2 gigs then you can obviously add another 2 gigs totalling 4gigs. This is a lot of memory for a system & although I'm not sure if your board can handle 2 gigs per bank, I personally believe that 8gigs is overkill & unneccesary.
Best wishes,
Graemevm
Jul 26, 2011 | DFI NFII Ultra INFINITY (NF2ULTRAINFINITY)...
Mo bo K7VTA 3 vers2 will not properly identify 1.4 Athlon chip - sees it as 900 Athlon. Ditto for 1800 XP - comes out as a 1.15. Using PC2700 DDR in lieu of PC2100. Can that be the problem?
Set FSB frequency from 100 to 133 and your CPU should be working at correct speed. The settings that you should apply are:
  • JP2: short pins 2-3,
  • JP3: short pins 1-2.
Jumpers are located near CMOS battery.
If this is the solution for your problem, please rate my post.
Regards,
Sep 07, 2010 | EliteGroup ECS Motherboard MB K7VTA3...
I need a diagram to hook up the front panel wires to a K7VTA3 Ver. 6.0 MO/BO. can you help me please?
hey there, click on the following link and download the manual, may take a minute. your diagram will be in there
seth
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2030&areaid=2&LanID=0
Jun 27, 2009 | Computers & Internet
Can cpu multiplier be set on ecs 6100sm-m mo bo?
Yes, I use AMD's program called Overdrive.
Be warned that increasing the mulipler also increase the voltage, don't go to high or you will have a smoked processor.
Apr 17, 2009 | EliteGroup GeForce 6100SM-M Motherboard
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
