Question about Welding Tools
Red arc comes on when gun signal starts checked cinsumables many times put on new parts, hypertherm 1650 plasma brand new
  • 71 Answers
Have you tried to tighten the end where the arc comes out thats what i do and that fixes mine
Posted on Aug 08, 2009
I need tips for my stud welding gun. How can I replace them? Thanks John
https://studweldprod.com/
Stud Welder - Stud Welding Equipment, Gun - Stud Welders Machine
www.eastwood.com > Welding & Fab
  1. Cached
  2. Similar
Stud welding makes more sense. Our stud welder systems each have a stud gun welder that spot-welds a series of pins onto the surface of the dented metal.
What is Stud Welding? ' Sunbelt Stud Welding
www.sunbeltstudwelding.com/studwelding.htm
  1. Cached
  2. Similar
Weld studs come in a variety of designs, threaded, unthreaded, tapped, etc., ... The welding gun is activated and the fastener is welded in a fraction of a second.
Stud Welding Machines and Equipment ' Red-D-Arc Welderentals
www.red-d-arc.com/rental-equipment-subcategories.aspx?sub_cat=180
  1. Cached
  2. Similar
Red-D-Arc offers a range of fully regulated, user-friendly stud welders, stud welding machines and equipment available in single or dual gun versions and ...
Jan 30, 2017 | Welding Tools
My pro cut 55 Lincoln plasma cutter sounds like a machine gun when I strike it and put it to the metal. It cuts holes when you hold the trigger down and try and make a continous cut. new air dryer
(From: https://app.aws.org/forum/topic_show.pl?tid=31328)
"Remember, they are a drag machine up to about 3/8" thick material. Keep the power down as low as possible for the material being cut. Keep the right air filters on to supply clean air. Keep the air pressure between 60 (min or it will shut down) and 70 for most applications (more is not better-just like oxygen on the torch or air to an air-arc).
Also, check that the air hose hasn't come loose from the gun.
That was Brian's problem from YouTube (http://www.fixya.com/answer/answerpageslideview.aspx?thid=26182813&ctg=373&brd=5236)
May 02, 2016 | Lincoln Welding Tools
I have Hypertherm Powermax 600 and the green OK light does not come on at times. I will let it set over night and it may come on or maybe not. Driving me NUTS!!! Please can you help. Thanks
you might have a bad relay on your circuit board. They arc and spot weld themselves at times (nothing a sharp hit can't fix) Replace the relay with a higher quality one if you can.
Oct 30, 2013 | Welding Tools
Thermal Dynamics Drag Gun Pac 10, Push Trigger, Labored Sound, Cuts Off and wont cut or flash arc. Cleaned Air Filter allways, All New Consummables, Allways kept clean, Has a rattle when trigger pressed...
Hi:
Your plasma has a start arc pilot inside the machine, this one must be faulty, check your owner's manual and request the part to your nearest welding store. It is easy to replace.
Jun 21, 2011 | Welding Tools
My Thermal Dynamic Drag Gun Plasma Cutter runs but cant blow its arc. Bit of spark, Bit of air, then just refuses to blow its arc. Was working well and with new tips and electrodes but then just refused....
Hi:
There is no mention of the Thermal Dynamic's gun model, but i will suppose that it is a SL60 or a SL100 which are replacement guns for any model of plasma using the proper adaptor.
Your problem could be the start cartridge which go bad now and then when the gun is used as a replacement of a hammer to make the cut piece to fall.
The way to check if your start cartridge is in good condition is by checking the low part of the cartridge, push it up (or down depending on the way you handle it) it should freely slide inside and return out.
Good luck.
Jun 16, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
My Hobart 250 airforce doesn't start
On the main circuit board for the power supply, there is usually a thermal fuse installed, its a sealed unit and is not servicible, look for a black epoxied case,approx 3/8x3/4 long, with 2 leads coming out of it. Inside is a set of bi-metal contact points which serves as an over voltage/over current protection. These contacts deform/corode over time and it sounds like there not contacting properly. As soon as you try to load the machine, the current passing through this high resistance heats these contacts up, and shuts off power to the unit. I am not familiar with the guts of a hypertherm, but have extensive experiance repairing inverter based plasma cutting equipment, and i have encountered this before. I assume hypertherm must have some equivelent to this thermal switch inside the power supply.....Good luck..
Dec 29, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
If you have a old plasma cutter can you swap ot
yes it does matter.each brand is set up for their own torches.
Jul 02, 2009 | Welding Tools
Hypertherm plasma cutter making weird air sound from inside unit
Open the cover (only after a day of not being plugged in).
Check the airline that comes in through the back of the case.
The air line has either fallen off or has a hole in it.
If you are a technician and don't mind working with thousands of volts of electricity that is inside the case, then and only then can you plug it in. Safety First. Rember the voltages inside this unit are lethal. It will not give you a second chance.
If you feel you are qualified, then plug it in and start it up, use it as normal, while at first watching from a 2 meter distance, you may immediately see and/or hear where the noise is comming from.
DO NOT under any circumstances put your hand or hands inside the box while it is live.
Try running a WOODEN stick (at least a foot long) along the length of the airline inside the case and around the valve as it enters the case. The sound should change in pitch when you find it.
If you think you have found it, DO NOT touch anything inside, until you have both DSCONNECTED THE UNIT from the power source and WAIT ONE DAY before putting hands inside the unit. Any storred or residual energy will have discharged by this time, making it safe to work on. Safety first. The voltages inside are lethal. This aplies to all Plasma Cutters. Good luck.
May 10, 2009 | Welding Tools
Red picture
Assuming this is a TV with a picture tube and not plasma or LCD; I'm afraid that your picture tube is dying on you one electron gun at a time. From what you said your green electron gun is almost totally dead and the two remaining blue & green guns aren't far behind. Eventually you'll have no picture at all and I would estimate that to be about 6 more months but whatever the time eventually it will go totally black. These blackout periods will get longer and longer. The only way to fix your problem is a new picture tube but my will probably find it less expensive to just get a brand new TV set.
Apr 14, 2008 | Toshiba 36A50 36" TV
Welding Tools Logo
140 people viewed this question
Top Welding Tools Experts
Bill Boyd
Marvin
Marvin
Are you a Welding Tool Expert? Answer questions, earn points and help others
