Question about Pitco Frialator SG18S Deep Fryer
High limit switch went out on deep fryer. Cannot find anybody that has part. The actual switch didn't have a manufacture listed on it just these numbers: E50023LR30247
  • 1 more comment
  • Blochead Dec 20, 2008
    I have one of these (same numbers) on my hot tub as well and need to find a replacement. It has a liquid pressure line and the line broke at the bulb. I do I find a new part or a replacement.
  • dreamteach45 Jan 01, 2009
    How do I replace an electric element
  • tlochs Mar 09, 2009
    need a high limit switch for a star deep fat fryer.. 450 degree
    Problem Solver:
  • 11 Answers
Call Pitco's 1-800 # for a authorized parts distributors phone # to buy parts. The part # to use for the OEM part will be -- # PP10084.
Posted on Feb 01, 2009
The thermostat in my hot tub has the exact same number on it which is odd, because hot tubs aren't supposed to go over 120 degrees. I wonder if the number stamped on the side of the part is fairly generic or merely refers to the casing.
If that's the case, you'll need additional info such the power rating on the fryer I suppose. I think fryers cooks at around 350 degrees -- maybe higher.
Also, mine has a sticker on it that reads TD103 149 and then below that 110F CR. I'm guessing that last part means 110 degrees Fahrenheit is where it tops out.
Posted on Nov 03, 2008
I have a EL120 with 1800 watt element...it will not get over 200 degrees F and is not due to a thermostat malfunction. Power is on constant 120V for over 30 mins but just wont get any hotter and is not...
You also have a high limit switch, which could be bad, or as you indicated, the elements could be bad as well? Do you know if the high limit switch is working? Do you have a reset button on yours?
If so, press that first and then try it....Thanks, Susan Restaurant Equipment Outlet-888-542-5959
Sep 12, 2011 | Cecilware EL-120 Deep Fryer
My keating fryer heats the oil fine to temp set on thermostat but will not re fire when oil temp drops unless I push the high limit button. Don't know if the problem is the themostat or high limit...
Sounds like the thermostat is working because it does heat to the right temperature, right? The high limit switch is to shut it down when it gets too hot, so why that helps the unit relight and heat up is strange? Is this gas or electric? Since hitting the reset or high limit button is what is working, I would start there, and replace that... I don't think either part is super expensive, so replacing both wouldn't be too expensive, especially since you have one of the best fryers ever made... Keating is number one in my book, and I know they are expensive to start with, but these two parts shouldn't be much....however I would start with the high limit switch or reset button... If you need a part, we can get you a price....I'm Susan with Restaurant Equipment Outlet, Cincinnati, Ohio, 888-542-5959, or you can ask for Paul too. Thanks, Susan REO
Sep 12, 2011 | Keating Instant Recovery 20AA (NG) Deep...
My fryer heat up to 285 then quit then try to light but want,
sounds like the high limit is doing what it is suppose to do. Check the actual temperature of grease with a perometer and see if it matches temp on computer if it is more than 10 degrees off or fluxuates irraticly change the temp probe. If it is dead on change the high limit.
Jun 25, 2011 | Frymaster Dean 2424G Deep Fryer
Can i disconect the hi limit switch and still use fryer
Hi there.
Hi limit switch/ device on fryers acts as safety device. It cuts gas supply on burners when it is triggered by high oil temperature in case the temperature regulating device failed to avoid further damage on equipment, property or life.
It is not advisable to operate the equipment with bypassed hi limit device.
I suggest to have it replaced first before putting the fryer back in operation.
For parts inquiry/ ordering, you can visit http://www.pitco.com
Regards.
May 29, 2011 | Pitco Frialator 35CS Deep Fryer
Can not get fryer to turn on. when you flip the switch to the on position, the high limit light flashes and go back off emediatly, and no power comes back on. i can here a click in the board behind the...
The High Limit is a self resetting thermostat that acually works like an oven control. If the fryer is too hot it will cut off the gas burner valve voltage:
OEM PN is 00-854453
Original PN VUL854453
Source 1
http://www.3wire.com/webstore/parts/PartSearchResults.aspx?searchText=Switch+High+Limit&mfrCode=VULCAN
$98.50
Source 2 Must log in.. new account
http://www.a1service.com/vulcan/vulcanlimit.htm
$90.20
The 854453 number comes up often in the part search for the high limit.
The high limit contacts can be checked and reading the NO and NC terminals. This control / switch is normally closed until opened by heat at 450 Deg F.
Thanks for Choosing FixYa,
Kelly
Sep 28, 2010 | Vulcan GRD45 Deep Fryer
How do I test the Pitco Frialator 35CS high limit switch
remove connections from hi-limit switch, and put an ohm-meter across connections then heat it with a match or heat source of that temp range,heat the face and watch your meter it will show open when hi limit reaches cutoff limit/if you need exact cutout temp,you will need to have one of those digital read-out temp gun
Jul 20, 2009 | Imperial IFS40 Deep Fryer
Fryer quits heating have to hit reset switch
This button should be a high limit switch. If it is a small red button mounted to a 2" x 2" or so device. You most likley have an issue with the thermostat letting it over heat. The best thing to do would be to replace both the thermostat and the high limit for safety reasons.
Mar 18, 2008 | Star Kitchen Appliances - Others
Frequent tripping of the hight limit switch
The high limit switch itself is getting weak , replace it and problem solved!
Sep 12, 2007 | Wells F-49 21148 Deep Fryer
Pitco Frialator SG18S Deep Fryer Logo
1,906 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Dan Webster
Dan Webster
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
