Question about Sharp R-1502 Microwave Oven
Won't stop runnig.
Sharp R1502 Microwave will not turn off until you open the door. Everything else works fine. Lighting struck by our home. The breaker for the microwave was tripped.
  • jasaxdad Jun 29, 2009
    I did not try to cook anything, so I really don't know. I do know the other things, fan, light work as they should normally. I can set the time for cooking. But since it runs no matter what (when the door closes), the time means nothing.
    Yes, the light, turn table, and the cooling fan comes on.
    I did do a check of continunity of the small transformers on the circuit board, and got 0.0 . I believe I should have received a least some sort of a reading.
    I hope I've given you the info you were asking for, if not let me know. Thanks.
  • William Miller
    William Miller May 11, 2010
    Are the inside light, cooling fan, and turntable all coming on with the door shut? Does it sound like it's cooking when the door is shut (and you have not set it to cook)? Does it heat water when the door is shut (and you have not set it to cook)?
  • Sharp Master
  • 9,098 Answers
Sorry, but it's still not clear, yet I can narrow it down.
First I would suggest you check the top & bottom door switches and mounts. (Don't worry about the middle one)
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
If it's not the switch or mounts, I would say the contacts of relay RY1 on the control board are shorted.
It's called the oven lamp relay, but it also runs the turntable motor and internal cooling fan when the door is shut.
If you or a friend have soldering skills, you can replace it (of course confirm first that it is shorted).
It's part number RRLY-A113DRE0 (zero on the end, not "oh").
You can order it from Encompass here or you can call them toll-free at 866-779-5835.
If you prefer, we regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 30, 2009
Sharp carousel 1200 watts microwave manual
They is one of the DOOR SWITCH need to replace
Aug 17, 2014 | Sharp R-1480 Microwave Oven
Sharp combo microwave: Turntable wont stop unless I leave the door ajar. Light stays on too while turntable is going. Everything else works fine - it just doesn't know when to shut up! :)
It's a door switch that's bad. Probably the secondary interlock switch. You need an ohm meter to verify switch not 'making' electrically. Usually the only thing that causes this switch to fail is from opening the door when the microwave is cooking, secondly, by cooking at very extended lengths of time.
Aug 28, 2013 | Sharp Microwave Ovens
Sharp Convection Microwave won't heat and turntable won't turn.
I typically find it is not door hinge issues but door switch issues, especially with sharp. You may heve a little movenent in the door hinge and that is allowing the door hook to move up and down on the plunger for a door switch that is probably a bit melted due to bad connections. If you check the door switches and look for any browning around the terminals where the wires push onto the switch you will probably find an overheated connectoion. Replace the bad switch and run better wires and better termninals to the new switch and it will probably be fine.
Oct 09, 2017 | Sharp R-930AK Convection/Microwave Oven
Microwave part is not working
There are several possible causes... none of which are user serviceable. Take unit to a shop for repair.
Possible problems include door switch, Magnetron, rectifier, control relay, etc.
Apr 12, 2010 | Sharp R-1872 Convection/Microwave Oven
My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Feb 14, 2010 | Sharp R-1480 Microwave Oven
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
Hi, My microwave oven stopped working after I came home from four days of vacation. The digital clock works. What could be the problem? The turn table does not work. Is there any danger opening back of...
if the clock is working then the fuse is fine. if the fuse goes bad the unit would be completly dead. no their is danger removing back panel. as you said make sure the unit is inplugged., however some electrical parts inside hold a charge until discharged.the board could be bad, the door latch or switches could be bad.
Sep 19, 2009 | Sharp Microwave Ovens
Sharp 1874- Door seems to "jar open" and oven stops
if you have a warranty get a new one installed they have to honor your warranty or better yet if they want payment you want new unit sometimes they come deffective from the factory ad you may have gotten one of them
Feb 20, 2009 | Sharp R-1874 Convection/Microwave Oven
Sharp Carousel Microwave R-1460A no power, door switch went first
You will want to replace the fuse and door switches. You will not be able to run it without replacing door switches. You do not need a new microwave. Door switches go bad, it has nothing to do with radiation.
Feb 19, 2009 | Sharp R-1460 Microwave Oven
Sharp R-1502 Microwave Oven Logo
114 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
