Question about RTO Stairmaster Clubtrack 510 Treadmill
I have a Quinton Clubtrack treadmill Error E105 NVRam Failure
I have a Quinton Clubtrack treadmill. Displays Error Code: E105 NVRAM Failure.
Manual instructs to push ''POWER, FASTER, SLOWER'' buttons to enter service mode. Unit does not enter service mode.
Thank you!
  • Anonymous Mar 21, 2014
    The treadmill track will not turn, console buttons do not work. Error Code S1 1 is displayed. What does that mean?
    Problem Solver:
  • 13 Answers
Fax me @ 281-469-9550 your full model number and I can fax you the setup modes.
Posted on Aug 10, 2009
Quinton treadmill E203 error VSD Lower Board
Quinton E203 Error, Motor Overcurrent (Overload) Probable Cause 1. Obstruction to motor pulleys or belt
2. Disconnected or loose motor lead
3. User outside the weight/speed envelope.
4. Excessive wear to deck/belt.
5. Motor.
6. Lower Electronics.
Corrective Action Quinton Treadmill Models: Club Track 3.0 and Hyperdrive
  1. Inspect for obstruction and remove if necessary.
  2. If the motor did not turn, inspect for loose or disconnected motor lead. Reconnect if necessary.
  3. Restrict users to weight capacity of unit. Restrict use to people that do not move slower or faster then speed setting.
  4. Inspect deck and belt condition. Deck should have a slick smooth surface, free of nicks, grooves, or rough areas. Deck should be flipped or replaced if necessary. Underside of belt should not have a hard glazed appearance. Belt should be replaced when deck is flipped or replaced.
  5. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If unit operates and then error appears again, replace drive motor.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is greater than 100 ohms, the motor needs replaced.
  6. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If error message appears immediately, replace the lower electronics.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is less than 100 ohms, replace the lower electronics.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Quinton Treadmill E203 Error Code
Feb 20, 2013 | RTO Stairmaster Clubtrack 510 Treadmill
Tip
How To Calibrate the Lift Motor on Quinton ClubTrack Treadmill
The following describes the steps required to calibrate the lift motor on a Stairmaster (Quinton) ClubTrack.
  1. Enter service mode on the treadmill by using the following keys at the same time:
    • Faster - Slower - Stop Belt
  2. Allow the lift motor to free spin by removing the bolts from the metal block on the jack screw.
  3. Press the up arrow on the control panel until the incline is at 5% then press the down arrow and take it back down to 0%. This will allow the lift motor rheostat to find its range.
  4. Spin the metal block on the jackscrew to allow 1 - 1.5 threads to be exposed from the top. Secure the lift motor back to the frame by inserting the 2 bolts through the bracket holes and into the metal block. NOTE: Double check the spacers on each side to make sure they are flush.
  5. Run the treadmill incline up to 15% and check the jackscrew to verify it has not bottomed out before reaching 15%. There should be around 4 - 6 threads exposed. Bring the treadmill back to 0% where there should be the same amount of threads exposed from the top of the jackscrew. If you see the correct amount of threads the lift motor is calibrated.
NOTE: If there is an error on the display panel, ex. E211, you need to manually turn the jackscrew back to 0%. To perform this unscrew the 2 bolts from the bracket securing the metal box and jackscrew allowing it to freespin. Use a shop rag or towel to wrap around the jackscrew to prevent damage to the threads. Using a pair of pliers (channel locks or vice grips recommended) manually turn the jackscrew back to 0%. Once this is accomplished run through the above steps to perform the calibration.
Quinton Treadmill Support How To Calibrate the Lift Motor
on Mar 10, 2015 | Quinton CLUB TRACK Treadmill
PLO5 error message on Quinton Clubtrack treadmill
Try to clear the error message. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
Quinton clubtrack treadmill shows E203 code, says drawing more than specified current. Could it be a bad motor?
5. Motor.
Dec 06, 2011 | RTO Stairmaster Clubtrack 510 Treadmill
954 service nvram failure huh
This is from Lexmark's support page....sounds like a hardware issue....
NVRAM Failure 953: NVRAM Chip Failure
954: NVRAM CRC Failure
Optra T 640/642/644
953 - Replace the operator panel board or upper front cover.
954 - Replace the interconnect card.
Mar 26, 2010 | Lexmark T522 Laser Printer
I have a quinton clubtrack treadmill with an E105 code
E105 means power interruption if this is a 3.0 or Hyper Drive just need to hit clear or start that should take of code until either it is unplugged another power outage
Mar 02, 2010 | RTO Stairmaster Clubtrack 510 Treadmill
QUINTON CLUB TRACTURNED MACHINE ON..THOUGHT IT WAS 220 VOLTS..SAW
This is most unfortunate if this either club track 510 or 612 your out of luck the electronics are no longer available. If these are either 510 or 612 you can get it repaired call National Gym Supply @ 1-800-496-7278
Jan 29, 2010 | Exercise & Fitness
I have a quinton club track treadmill that posts an E203 error
E203 = Motor unable to run. Usually caused by the VSD Lower Board. This board is about 14" square on a Quinton Clubtrack Hyperdrive 3.0
Rather difficult to remove escpecially if your not familair with electronical compnents in a tight space.
My reapir coast $374 from J&R Technical Services and exactly one year later I got the exact same code. Warranty is 90 days.
It appears they rebuilt one of the components on the board called a Phase Modulator. There are three of them. They stated they had replaced it, but upon close inspection it appears that simply replaced the bad micro-component on the modulator and reinstalled the exact same phase again.
I'm debating whether to trust them once again. Little choice though since they control the market and have the equipment to reset the board upon repair. Nobody at thome has this equipment.
Sep 15, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
My Lexmark T522 printer is showing: 954 Service, NURAM Failure
info from the lexmark site:hope it helps!
Printer is Posting a 953 or 954 Service NVRAM Failure Message ID: ENUS9756
To clear an NVRAM error message:
Turn the printer off.
Leave it powered off for at least a minute to give it a chance to reset, then power it back on.
If that clears the error, continue using the printer but keep an eye on it for the next day or two to see if the error returns. If the error does not return, the printer should be fine.
If the NVRAM error does return, you can try resetting the printer's NVRAM as follows:
Now press and hold down the right Menu arrow button (>), the Select button, and the Go button at the same time.
While continuing to hold all three of these buttons down, turn on the printer.
Keep holding down the buttons until the printer displays Clearing NVRAM or Restoring Factory Defaults, indicating that the printer is performing an NVRAM clear. You can release the buttons at this point. WARNING! Do not power off the printer during this process.
When the printer has finished the NVRAM clear, it should return to the Ready mode.
If the printer has not gone back to Ready after fifteen minutes, turn off the printer and then turn it back on again as you normally would.
If these steps do not clear the NVRAM error, there may be an issue with an installed option on the printer. Electrical options (like flash memory, network cards, code SIMMS, and additional RAM memory) are the most likely causes. To see if an installed option is causing the error:
Turn off the power and remove any options that have been installed. (For information on removing memory or code SIMMs, click here.)
Turn the printer back on.
If the NVRAM error continues, the printer will probably need service.
If the NVRAM error is gone after you have removed all of the options, power off the printer again.
Reinstall the options one by one. Power on the printer each time to see if the NVRAM error returns.
If the NVRAM error returns as soon as you reinstall an option, that option may be causing the error.
Remove that option.
Turn off the printer and reinstall all remaining options (if any). If the NVRAM error appears only when that one particular option is installed, that option may be defective or incompatible with the printer.
If you can reinstall all of the options and the NVRAM error is gone, an option may have been loose and simply needed to be reseated. Again, keep an eye on the printer for the next day or two to see if the error returns. If not, the printer should be fine.
If your printer looks like it will need service and it is still covered under its factory warranty, click here for information on how to contact Lexmark Technical Support.
Nov 19, 2008 | Lexmark T522 Laser Printer
RTO Stairmaster Clubtrack 510 Treadmill Logo
795 people viewed this question
Top RTO Exercise & Fitness Experts
Howard
Howard
Jax Planet
Jax Planet
Marvin
Marvin
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
