Question about Philips Nino 210
How do i reset my handheld
I forgot my password to my handspring visor graphite. what buttons do i press to reset it? i notice there is a reset hole in the back however when i press this, it does not reset itself.
0 characters
1 Points
I have a Handspring Visor Graphite Handheld and when i shnged the bateries i lost all my data. Anyone can help?
If you have hotsynced your Visor with a PC (or Mac), the first time you sync your Visor to that computer, it should restore all the data from the last hotsync to the PDA. This is one big reason that it makes sense to sync your PDA on a regular basis.
Unfortunately, if you never used the hotsync function for your Visor, you may not be able to recover any of your data. This model Handspring Visor requires good batteries or else everything in its memory will randomize and you will lose all stored information. There is a small capacitor in the Visor that provides enough reserve power for about 30-60 seconds when you pull out the batteries. It's for this reason that Palm recommended pulling out only one battery at a time when changing to a fresh set. That minimized the amount of time that the PDA would be without power. That same advice applies equally to Visor PDAs.
Jun 15, 2011 | Handspring Visor Graphite Handheld
Is it possible to restore the OS in a Handspring Visor Prism?
You will need to do a hard reset as follows:
To perform a hard reset:
1. Hold down the power button on the front panel of the handheld.
2. While holding down the power button, use the reset tool (or
similar object without a sharp tip) to gently press the reset button.
3. Release the power button.
4. When a message appears on the handheld screen warning that you
are about to erase all the data stored on your handheld, do one of
the following:
Press the top scroll button on the front panel of your handheld
to complete the hard reset and display the Digitizer screen.
Press any other button to perform a soft reset.
Note: With a hard reset, the current date and time are retained.
Formats Preferences and other settings are restored to their
factory default settings.
After performing the hard reset the OS will be just as it came out of the box when purchased.
I hope this helps, if so please rate our solution.
Corporate Computer
Sep 15, 2010 | Handspring Visor Prism Handheld
How do u pair supertooth visor go to phone
Put your bluetooth on your phone..
On the supertooth is a green and hold to turn on for around 5 secs and watch for red and blue lights to flash..its pairing activate phone discoverable. .and pair..enjoy
Aug 05, 2010 | Handspring Visor Prism Handheld
I have a koto sun visor bluetooth, i have bought a new phone but cannot put the new phone on can you help please as i have mislaid the manuel thanks
if you can not put the phone on, try putting it in the charge for 5 minutes to show its working and press each button for 3 seconds and something should strike lucky
Jul 03, 2010 | Handspring Visor Prism Handheld
Seal handsfree not pairing
with the phone's bluetooth active
press button to turn the seal device
press blue button on seal device
on phone, select pair new device
when the seal device is found, use code 0000 to pair the phone to the device..
next time you connect, turn on the phones bluetooth and the seal device. press blue button on seal device. it should automatically pair.
Sep 15, 2009 | Handspring Visor Prism Handheld
Can't get device to hotsync
First thought is that the cable has become defective - they do go wrong.
Assuming the visor is fine other than when hotsyncing, I suggest you reinstall the Desktop manager and hotsync manager on your PC or Mac, HAVING BACKED UP ALL FILES of course.
Sometimes the managers get corrupted and cause problems. Try that first, then check cable and finally a hard reset, assuming you have hotsynced recently and so won't lose loads of information.
May 21, 2009 | Handspring Visor Deluxe Handheld
Visor Deluxe OS3.0.1 Fatal Error
Your application is for an upgraded version of the Palm OS. Say you had a Palm OS version 2 or something. If you download an application for Palm OS 5, obviously it won't work because the application is for a later version. Make sense? To remedy this, you will have to delete the application and get one with a version that matches or is lower than your Palm's.
Mar 16, 2009 | Handspring Visor Deluxe Handheld
Hi I have a Seal Bluetooth visor hands free kit for the car I have misplaced my instructions can you help. Kind regards Brian
visor is off press and hold the multi function button for six seconds . the red and blue leds will flash alternately and the speaker will make a long beep sound . Then enter the PIN code 0000
Mar 01, 2009 | Handspring Visor Prism Handheld
Congratulations on your 'first generation' Handspring Visor purchase. While perhaps 'old technology' in the techno world, I am still using mine today. To answer your question, your Visor is simply attempting to 'synch' with your desktop files (to ensure you have the correct data in both places. Your error stems from the fact that the unit is 'searching' for your desktop files to perform that handshake. Like an unanswered telephone; your Visor 'hangs up.' You will need to install the software on your PC. Yes, there is still software out there. ;-)
Nov 29, 2007 | Handspring Visor Prism Handheld
Philips Nino 210 Logo
Top Philips PDAs Experts
Are you a Philips PDA Expert? Answer questions, earn points and help others
