Question about Honda Maxus Pressure Washer MX5222
Honda XR2750 only runs on full choke
If I tried to take off choke, engine immediately dies. The pressure washer has sat for at least 6 month. After running for about 10 minutes, it now won't stay running, even on full choke.
  • lamorey3 Jun 27, 2009
    Is it possible to spray a carb cleaner into the choke area, short of a carb rebuild? I'm reasonably mechanical, but have never taken a carb apart. Thanks. Lynn
    Thank you. As you suggest, I'll take my time and take a few pictures.
    Sergeant:
  • 353 Answers
Remove and clean entire carb
there is a passage clogged with old fuel gum
use STA-BIL fuel stabilizer in the future
Posted on Jun 27, 2009
  • gerald darling
    gerald darling Jun 27, 2009
    i would start by just removing the bowl and clean it, if there is a green or brown deposite in there the whole carb may need cleaning
    they are fairly simple. just have a table to do the disassemble on and take you time
    just remember how it came apart(if it helps take pictures) and don't spray cleaner on any part that isn't metal
    i'm afraid carb cleaner in the choke won't solve your problem
    good luck
Why does Honda GX340 die immediately despite fresh gas, cleaned carb, and new plug?
Perhaps you haven't adjusted the carburetor correctly.The fuel supply orifice could be still plugged . Recheck the carb.
Aug 27, 2014 | Honda Gx340 Gas Engine 11hp Motor Pressure...
My Honda XR2750 pressure washer doesn't seem to be spraying a full capacity. Is there a blockage and /or filter I can clean?
Usual cause is the water admitance valve that regulates the pressure by admitting more or less water.
Remove the valve parts and clean the bore with crocus cloth on a dowel rod. Replace the O rings and lube with plumber's grease.
Re-assemble.
Jul 15, 2010 | Garden
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
Won't start, can't remember starting procedures and dont have manual
Make sure the fuel valve is on. Generally that means pointing down inless there is a diagram on it.
Turn the switch on.
Pull the choke on the carbuerator on full. There will be a picture of a butterfly valve set it so that it is closed. Pull the cord till the engine fires. let it sputter for a second, then open the choke. If the engine dies right away, do all of the above again but once it fires, only open the choke half way. once it warms up a bit open the choke completely.
Dec 22, 2009 | Honda Pressure Washer PSI 3000
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
I'm trying to find out how much oil should be in the water pump of a honda pressure washer model xr2750-1
it's an ex-cell pressure washer with a honda motor.
engine oil capicity: 0.61 qts(.58L)
view owner manual here:
http://www.excellpressurewasher.com/documents/pdf/a12338-e.pdf
Mar 10, 2009 | Honda Garden
% hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Regards,
MG.
Nov 02, 2008 | Karcher 2500 PSI Pressure Washer
Choke needs to be on all the time
your problem is in the carb. for some reason there is a stoppage or clogg in the venture opening that feeds the main passage to the manifold. that is the little pipe connecting the carb to the engine.the choke being on causes the engine vaccum to **** gas from other resourses in the carb to run. also check to see if throttle butter fly is moving freely.there may be a defect with the carb and they will have to replace. running the engine with choke on causes it to run rich and will foul the plug eventually . also not good on gas . will use way more than it should. also co2 level way up.
May 21, 2008 | Karcher 2500 PSI Pressure Washer
Honda Maxus Pressure Washer MX5222 Logo
1,055 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
