Question about Sunpentown Heating & Cooling
Sunpentown WA-1210E recharge: This systems seems to have lost some of its punch. Before I tear it open, is it possible to recharge the refrigerant on these? Please shoot a response to roywatson@smartscan.biz
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Why is my sunpentown WA-1210H portable AC not
Might be a dirty filter, a burnt compressor wire or a bad capacitor. Or it could be a bad thermostat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 10, 2009
2rns4u
  • 22 Answers
SOURCE: Sunpentown WA-1210E
The unit is probably undersized for the space. Rule of thumb is 12000 btu per 500 sq ft. Take a thermometer and measure the entering air to the unit and then hold it in the outlet air stream you should see a temp. difference of about 10 to 15 degrees if it functioning properly. Hope this helps 2rns4u <*{{{>(
Posted on Jul 22, 2009
2rns4u
  • 22 Answers
SOURCE: My Sunpentown WA-1210E airconditioner stopped
Have you checked the water container in the unit? It has a float switch that when it is full it will not allow the unit to run so that it will avoid spilling water on to the floor. Hope this helps 2rns4u <*{{{>(
Hi my wa-121oe is not blowing cold anymore
hi.maybe your compressor not working maybe you need charge.
Jul 16, 2014 | Sunpentown WA-1210E Air Conditioner
Need instruction manual for Sunpentown WA-7500M
You can get the manual on the link below I hop it will help you.
http://www.sylvane.com/images/productpages/sunpentown/manuals/WA-7500M.pdf
Good Luck and please rate 4 thumbs up for the free answer
Jun 19, 2010 | Sunpentown 7500 BTU Portable Air...
Sunpentown WA-1210E
Jul 22, 2009 | Sunpentown WA-1210E Air Conditioner
My Sunpentown WA-1210E airconditioner stopped working. It emitted several beeps and the power light is blinking continuously. When I unplug, wait a few minutes and replug in the unit, it shows the same...
Jun 29, 2009 | Sunpentown WA-1210E Air Conditioner
My Sunpentown WA-1220E portable air conditioner is not working. Comp light is flashing (red light). Any idea what could be wrong?
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Jun 28, 2009 | Sunpentown WA-1220E Portable Air...
Air conditioner
filters blocked or fan cage full of dust cant pickup the air if this is a zoned system then maybe zone damper is stuck not letting the air through
Jun 20, 2009 | Sunpentown WA-1210E Air Conditioner
Why is my sunpentown WA-1210H portable AC not blowing cold air anymore?
May 10, 2009 | Sunpentown WA-1220E Portable Air...
Fan blows.. no cold air... no hot air exhaust blowing
This sounds like you either need to clean or replace the filter, but if the filter is some what new you might want to take a look at the coils just past the filter, if the coils do not have a shine to them then you might want to buy some coil cleaner (i found simple green or formula 50 works great), then you will have to spray the coils with the cleaner, let sit about 10-15 min, then give it a very good rinse with warm water. After that it should work like it is brand new. Enjoy!
May 28, 2007 | Sunpentown WA-1210E Air Conditioner
My unit turns off by itsself
Probably is the problem. These units have a float switch in them and won't run if they fill up to protect your floor. What you can do is connect a tubing to the drain pan and either drain it out side or into a larger container. Hope this helps 2rns4u <*{{{>(
May 10, 2007 | Sunpentown WA-1210E Air Conditioner
Heating & Cooling Logo
130 people viewed this question
Top Sunpentown Heating & Cooling Experts
Steve F
Pete Norton
Michael Youngman
Michael Youngman
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
