Question about 2wire 2700HG-B Router (2700HGB)
How to set 2wire 3600 hgv - 2wire 2700HG-B Router (2700HGB)
For got the password to my modem 3600 with att
press the reset button on the back side of the modem and restart it to get effective,
Oct 11, 2013 | 2wire Computers & Internet
I have a foehn and hirsch g422 sat nav and am unable to pick up gps program. Its is saying to set the GPS path in file manage. Also i was told it had hgv settings but cant find them.
hgv settings easy to get go to gps settings go to route then at bottom of screen it will say settings eg car click on it and then pick truck one edit it to what ever you need
Sep 22, 2011 | GPS
I have a d-link dwa125 wireless adapter that wont connect to my 2wire 2701 hgv-w wireless router. I can connect my sony ericsson xperia x10 to it but when I use the same password for my computer it wont...
the security enabled in the router is compatible with mobile but not with computer this is the reason...check the security enabled in your router...64 bit WEP (open) security is compatible with all the wireless devices... by default some routers will have WPA or WEP(shared) security... these securities are not compatible with certain computers...
Aug 20, 2010 | D-Link Computers & Internet
I have 2wire gateway 2700 bt hgv has very poor wireless range who can i improve this
hi,
see if the antenna screws off the router, if so I suggust to look carefully at wireless antenna from Maplin , RS and so on.
If the antenna does not remove , have a look for a gold plateted plug so you can plug in a external antenna.
Regards
GeWiz.
Dec 10, 2009 | Computers & Internet
I am trying to port forward d-link DCS-2121 camera to 2WIRE 2701 HGV-E. pls help a complete idiot.....
Instead of walking you through it here, it will be much simpler (for me, and probably you too!) if I link you to the most informative database on the subject ..and a page dedicated to your 2WIRE:
http://www.portforward.com/english/routers/port_forwarding/2wire/2701HGV-E/default.htm
Aug 31, 2009 | D-Link Computers & Internet
Wireless Devices won't connect to 2Wire Modem
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
good luck
Aug 06, 2009 | 2wire HomePortal® 1800HW Router...
How do I connect a Linksys Wireless-N Model WPC600N to a 3800 HGV-B Gateway modem/wireless router use for ATT U-VERSE service?
hi! u need to setup the wireless settings of your modem/wireless router in order for the wireless network adapter see ur wireless router, check ur wireless settings first. or try to contact ur isp provider who supply the model/wireless router..
Jul 17, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Wireless printing with AT&T U-verse and 3800 HGV-B and Linksys WPSM54G
I may not be able to completely solve the issue for all who posted, and I have not gotten the scanner part of my Brother MFC-5440CN printer/scanner/copier/fax to work through the wireless PS, but I can at least shed some light:
First off - trying to make the Linksys WPS54G work on a wireless network that has a decent level of security is NOT for the faint of heart!
Key issue is security; make sure you know what wireless security protocol your router is using (WEP-64, WEP-128, or WPA). My U-verse installation uses the exact same 2Wire router, but either it defaults to WPA security, or the tech set it up that way without asking me. WPA is preferable anyway, as it is the most secure, and I had my network set up on WPA with my ZOOM X6 when we had AT&T DSL.
The problem is that the Linksys unit is old/obsolete enough that it defaults to WEP or no security, and in fact the setup program and utilities on the CD that came with the refurb. unit I recently bought are way outdated compared to the current downloads available on their support site, and don't even offer WPA as an option.
If your U-verse router is configured for WPA, as is most likely, then you have to get your Linksys unit configured for WPA security before it can be properly "seen" on the network by your computers. This means either downloading the latest setup/driver programs from Linksys's support website and burning a fresh setup CD, or getting to the Web-interface of the unit and setting it there (I could not even get to the web-interface because of my firewall and other security). Only then can you set the unit to use WPA security with the same key/passphrase as your U-verse router and your computer(s).
I'd advise downloading the latest stuff in any case. I ended up downloading the latest firmware, upgrading it on the unit using the Bi-Admin util on the setup CD, setting up the unit using the web-interface (be patient, because sometimes the page loads can be very slow when it is reading or writing settings). I have never been able to access the web-interface from my laptop, which is probably the most secure on our network. I was only able to get things working when I accessed it from an old PC we rarely use, and it is only running Windoze (XP) Firewall for security. The print server had to be Ethernet connected to the router while doing the configuration to make it work.
Jul 22, 2008 | Computers & Internet
2wire 2700HG-B Router (2700HGB) Logo
52 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
