Question about HP Hewlett Packard Pavilion Slimline S3100N PC Desktop
How do i remove the dvd from an hp s3100n desktop.
Trying to reach the memory stick but the dvd is in the way, need to remove the dvd to access the memory.
    President:
  • 948 Answers
You need to take the cover off the computer on both sides. Normally the optical drive is secured by four screws, two on the left and two on the right. Take those screws out and slide the drive forward enough to get to your memory stick. You may not have to unplug the cables, but if you can't slide it out far enough you will.
Posted on Jun 27, 2009
  • Dick
    Dick Jun 29, 2009
    How did it work out Gus? Drop by and rate the solution if it worked for you.
I Have an HP pavilion slimline s3100n desktop pc and when i turn it on the blue light is lit but there is not power on the usb cables and i cant see anything on my computer screen but the fans are working...
Without additonal information, it is difficult to offer specific suggestions, but:
Are the video connections to the computer/computer card and the monitor tight?
Is the monitor turned on? Sorry - I had to ask.
Do you have access to another monitor? Does it work on your computer?
Do you have a video card on a computer which has its own, built-in video card? If so try switching where you attach the video cable. Once I had to physically remove the seperate card, attach to the built in output and all worked well.
If you have access to a working computer, you can go to:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph04760&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=3440586
for additional information.
Dec 25, 2010 | HP Hewlett Packard Pavilion Slimline...
Hp pavilion slimline s3100n doesn't display on the monitor. boots fine and fans spin and stuff, it just doesn't recognize its own VGA output. What do i do?
Hi
First,try hooking it up to an external monitor if you have access to one.Unfortunately,we need video to start checking for what may be wrong.
Try the monitor and post back to let me know what happens,and if it shows on the external display we can start looking at potential problems and fixes.
Bob
Aug 21, 2010 | HP Hewlett Packard Pavilion Slimline...
Looking for any complaints regarding the motherboard for the HP Slimline s3100n.
HERE is a whole site of listed complaints regarding the computer you listed. HP Slimline s3100n. I hope this helps and is what you were looking for.
Jun 22, 2010 | HP Hewlett Packard Pavilion Slimline...
How do I get the DVD out of my s3100n slimline pavilion HP in order to install add'l ram
Most slimeline cases have DVD that remove from the front. That is you will have to remove the front plate of the computer to slide the DVD out. Close to the inside corners on the front usually are compression fit plugs that snap into place, ocassionaly screws but not often. Take your time and slowly push them outwards once you have all of them loose on one side you can gently rock the front back and forth until the other side dislodges.
It is important to not use excessive force or you could break the pins in which case you will need to have some glue handy.
Feb 05, 2010 | HP Hewlett Packard Pavilion Slimline...
I want to upgrade the RAM, and when I opened the desktop the dvd is positioned over the memory slots. I CANNOT FIGURE OUT HOW TO REMOVE THE DVD TO SWOP OUT THE RAM
see if there the motherboard is secured onto a rack that can slide out of the casing. most newer computers have this feature. if not, you will have to unscrew the dvd drive from the casing to get to memory slots. unplug the drive, find the mounting screws, and remove the drive. remember to plug everything back up (power, interface cable, digital cable if present).
good luck.
Oct 15, 2009 | HP Hewlett Packard Pavilion Slimline...
How do i remove the dvd from hp s3100n
Hey there, sounds like it is stuck in your drive? Simple, there is a small hole in the front of the drive, put a paperclip in there to push the drawer out
Jun 27, 2009 | HP Hewlett Packard Pavilion Slimline...
RAM replace on Hp pavilion slimline s3100n PC
Ok, what you've got to do are the following.
1. Remove outer cover. (you've obviously already done this)
2. Remove holder for personal storage device.
Pull up brown/black lever untill the unit lifts up and out
3. You can now see black screw holding in DVD/RW Drive - remove it.
4.Lift latch that you described
5. Push DVD Drive forward until you can access the memory
Jun 24, 2009 | HP Hewlett Packard Pavilion Slimline...
HP Pavilion Slimline S3100n keeps shutting down to powersave
It may be a virus or trogan problem. DO clear the Internet explorer cache and browsing history. remove all unwanted programs using add remove programs. please reply to me if u can solve with thos solutions
Apr 06, 2009 | HP Hewlett Packard Pavilion Slimline...
Can't remove housing to put in memory card
unscrew the one side and slide it back toward you and the other side just slides off
Mar 29, 2009 | HP Hewlett Packard Pavilion Slimline...
HP Hewlett Packard Pavilion Slimline S3100N PC Desktop Logo
205 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
