Question about Acer Aspire 6920 Notebook PC
ACER 6920G BLANK SCREEN BIOS BATTERY LOCATION? MOBO JUMPER?
Anyone know where i can find either the bios battery or the jumper to reset the CMOS? i have a picture of the board here, it is one that uses the NVIDIA 9500m GS, not intel on board graphics [img]http://74.52.128.226/~metalex/leicesterlaptop/2009/FEBRUARY/02-03-09%201.jpg[/img]
  • olihodgson Jun 27, 2009
    i wouldn't know how to do that without seeing the screen unfortunately. i am in the process of trying to flash the 9500m GS card at the minute using a USB blind flash, hoping that may do something
    Problem Solver:
  • 8 Answers
Hi there, I had the same problem. nothing on the screen.
Take off laptop battery, remove power cord, turn laptop upside down.
Just take off 6 screws on the cover which let you see HDD, Memory,.... ,
take off hte cover .now check on line how to remove the rest of the plastic cover which covering the CMOS battery which is wrapped up with yellow tape. Just remove the battery by holding on the white connector which attached to the motherboard with black and red wires. Gently pull from the motherboard.
Now without the CMOS battery, connect power cord and turn on the laptop, it should turn on. Now turn off , remove the power cord, check voltage on battery , it should measure very close to 3volt, otherwise get a new one, connect the battery, put back both covers, and you are done.
Posted on Mar 12, 2013
  • Kiru Pera
    Kiru Pera Feb 25, 2015
    Just take off 6 screws on the cover which let you see HDD, Memory ,video card, fan, CMOS battery.
    take off the cover, Look for white connector, right below video card, connected to the motherboard with red and black wires,on the other end of the wires, CMOS battery is connected which is wrapped up with yellow tape, but battery would be hiding under the rest of the bottom cover. Just remove the battery by holding on the white connector which attached to the motherboard with black and red wires. Gently pull from the motherboard.
    Now without the CMOS battery, connect power cord and turn on the laptop, it should turn on. Now turn off , remove the power cord, check voltage on battery , it should measure very close to 3volt (2.8v - 3.0v), otherwise get a new one, connect the battery, put back cover, and you are done.
    Important: If you find before this problem, your Battery does not hold the charge or does not even charge, do not connect back the battery, get a new one. Sometime even a dead battery can cause these problem.
    This will fix problems like
    1)when pressing the power button , power LED blinks and nothing else happens
    2)laptop power up but you get the screen comes on, but you get
    " CMOS checksum error", in this case change the CMOS battery.
    Kiru Pera ( edited the previous answer)
  • 334 Answers
Hey there, not sure if you can do this or not but it will clear your cmos. Boot up MS-DOS and enter the DEBUG program. Type the following commands: The following commands will clear CMOS:
-o 70 2e <CR>
-o 71 ff <CR>
-o 70 2f <CR>
-o 71 ff <CR>
It may be necessary to reboot the computer a couple of times to correct any CMOS and errors.
Posted on Jun 27, 2009
Hi im trying 2 reset my bios but carnt get in there i need 2 know what on and off pins on the board i can take off and where r they located
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don
Mar 25, 2011 | Acer Computers & Internet
I need the backdoor password for the bios. Or a key seq. to remove or reset the bios password.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
or
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC
Dec 30, 2010 | Acer Aspire 3000 Notebook
A friend has an Acer Aspire 5341 and needs to reset the bios password. Now, she said she had taken out the "bios battery", let it rest for a bit and then placed it in again but this did not work. Any help...
it is not only about removing the battery and replacing it.there are other steps to be taken.Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
Make sure to turn the PC off before opening the cabinet and resetting the jumper. another option is by using a software the BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds.vote me if this works for her.best luck!
Jun 17, 2010 | Acer Aspire 9300-5349 Notebook
Where are the bios reset pins on apire one aod150
Here is the BIOS reset pins and the CMOS battery of acer laptop. You can reset BIOS password also trough removing the CMOS battery. 04ebfdf.jpg
Apr 03, 2010 | Acer Aspire One AOD150-1920 Netbook
How can i reset my bios password for an acer aspire laptop?
IF YOU KNOW THE BIOS PASSWORD YOU CAN GO TO BIOS AND CLICK ON CHANGE PASSWORD AND IF YOU FORGOT THE BIOS PASSWORD YOU NEED TO OPEN THE SYS. AND ON MOTHERBOARD THEIR IS A SMALL JUMPER THAT SAYS BIOS JUMPER ON IT YOU NEED TO REMOVE IT AND PUT IT IN PRONK 2 &3 AND RESTART THE SYS. AND THEN AGIN TURN OFF THE SYS. AND PUT THE JUMPER BACK TO PRONK 1 & 2 AS IT WAS EARLIER. AND IT WILL REMOVE THE BIOS PASSWORD.
Oct 25, 2009 | Acer TravelMate 2300 Notebook
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
Please help me reset my bios password on acer travelmate 2410
First you need to remove the laptop battery at the back side. Find some screw there and remove it locate the CMOS battery and jamper.
Oct 08, 2009 | Acer 4220-2346 Notebook
Compaq 8150p bios password need to be reset. Is the cmos battery soldered on or unplugable.
The BIOS battery could be a button type battery or it could be a battery with a plug-in lead.
Oct 08, 2009 | HP Compaq 8510p Notebook
BIOS Password for ACER Travelmate 2355LCi laptop
on the botom of the laptop there are some switches probably one has moved or you changed it by mistake
Feb 12, 2009 | Acer TravelMate 2355LCi Notebook
Acer aspire 3100 series
If you where the CMOS battery is, there's beside it a jumper inserted in two of the 3 pins(left pin and middle pin). Remove the jumper from its original position and with it short the middle pin and right pin. This resets the CMOS ROM to its default settings minus the password. Return the jumper to its original position as before. Reboot the computer.
Apr 25, 2008 | Acer Aspire 3100-1405 Notebook
Acer Aspire 6920 Notebook PC Logo
1,737 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
