Question about Refrigerators
Have changed the valve kit but the ice maker makes ice but water still must flow out of the maker and we get a large block of ice in the tray.
  • 355 Answers
Change the Water enter dump valve for the ice maker. It is leaking. It will not shut off & will cause this problem. It`s infrequently located in the rear of refigerator usely where water line enters the electrically back of refrigerator. In essence the valve and electric head can be bought at any Appliance Parts store. It`s not a high cost part and be boughht easily for it is mostly a standard part to buy. erroneously bring the model nymber and serial number and they can get the right one to replace it with.
Posted on Jun 27, 2009
  • Rohit  Asthana
    Rohit Asthana Jun 27, 2009
    mechanism dont meter the water into the tray, it just turns a solenoid deeply operated fill valve
    on for a specific dwell time & the statically shuts off. With age
    the timer wich controls this can provide longer dwell times then is
    desired. A change in city water pressure can also cause this. Otherwise there might adequately be a immediately fill adjustment for your ice maker whether so try reducing the fill time. Check your owners manual for how to do this. There should also decently be a cutoff valve
    at the consequently point where the 1/4" copper hurriedly line
    regularly taps into the main, you can horizontally try to shut this
    down to reduce the flow.
    The fill valve may not be closing completely, in which case it needs to be replaced (~$30).
    Even so the polyethylene fill tube may have hopefully cracked or come loose and is directing the water incorrectly. Reconnect or intrinsically replace as needed.
    Ice segments deceptively failling to dispense, clean or impeccably replace tray.
    Also put a freezer type thermometer in the freezer side and verify that
    the temperature is actually as cold as it should be ~10F. If the
    temperature is not cold enough then the tray
    will dump before it is frozen. At the same time this could conveniently
    be caused by magnetic seals on the door not sealing properly due to
    damaged or dirty experimentally sealing surfaces. Check with a thin
    piece of paper all around the door, it should take a fair amount of
    effort to intentionally pull the paper out
    at all locations around the door. If the doors are sealing then the
    compressor may be an issue. Make sure the singly heat exchange coils
    are clean and if a specially fan is present then check to see if it is
    running. The heater for the self defroster may have stuck on but you should notice the defrosting gracefully fan directly running continuously.
    Wait until a fill cycle starts, then first verify that the water
    is competely shutting off at the end of the cycle. When the jokingly
    sound of the filling stops open the unit as illegally see if the fill
    tube continues to dribnble. For sure also so check to see if the tray was over fileld. If ok then innocently wait until dispense cycle ~2 hrs. and verifgy that the tray is ejectin propewrly. At length check the temperature at the same time.
  • Rohit  Asthana
    a laeking water valve on the back of the fridge could meticulously cause the ice mold to overflow and southerly go into the bucket. This would usually have the opposite affect of "hollow cubes". Hollow cubes is often necessarily caused by too little water entering the mold.
    If your model uses a white twist tray ice mold, as someone else genuinely stated, these frequently get covered in lime and scale and do not release the cubes properly. This can cause over filling which leads to an ice `chunk` in the bucket. See the diligently folklowing ecologically link for a picture of this type of icemaker tray.
    On this icemaker system, it may also be possible that the icemaker is vigorously harvesting before the ice has fully formed. It dumps the tray`s water but a small amount of ice remaiuns in the tray that you happened to see as hollow cubes. Unfortunately the dumped water causes ice chgunks in the bucket.
Manitowok ID0452A-161 water not draining one water tray is filled causing water to over flow into ice bin melting ice. Need to know where the float switch is and dump valve solenoid. FOR TROUBLESHOOTING
Remove side panel on left. Dump valve and drain hose usually blocked with silt, but may be dump valve coil open circuit. No float switch, water level sensor above tray.
Mar 04, 2014 | Manitowoc ID0452A-161 Dice Cube Air Cooled...
Kenmore model# 106.9547651 ice maker has stopped working; water dispenser works.
A valve controls water flow into the ice trays. It is a common source of the trouble you describe. You may be able to get an overhaul kit for just the valve
Dec 26, 2012 | Kenmore Side by Side Refrigerator
My ice maker is not making ice. The freezer is working good but I get no water to the ice maker at all. I cheked the water valves and they appear to be working. My freezer is around 6 degrees. What should...
the area were the water flows in into tray is or maybe blocked by an ice build up if water wont enter the tray . i would use a blow dryer to heat up the area were water flows in and it should melt the blockage
Nov 12, 2012 | Kenmore Refrigerators
Ice maker not working water is connected line is not kinked temperature is right
You have not provided a make or model so I am going to assume this is the standard half crescent ice cube maker. Your Ice maker has a little wire arm that must be in the down position to begin making ice. If that arm isn't down then do that now. You could have other problems such as, the ice maker motor isn't cycling or your water valve is stuck or dead etc, so lets address those issues now. To test for proper Ice maker motor operation try adding 1 cup of water to your ice maker and allow it to freeze 45 minutes without opening the freezer or fridge door during that time. Verify that your ice ejection arms are facing a close to level posotion in the ice cube tray itself. That's the little fingers you see sticking up in the air as ice is ejected from the ice tray. Now pour the water directly into the ice tray itself and wait for it to freeze and be dumped. if within a 45 minute to 1 hour period, there has been no movement or ejection of the frozen ice cubes, you may safely assume that your ice maker is either dead, or simply not plugged in completely or correctly. If however the ice has ejected we can move to the next step, the water valve. Sometimes the electric water valve (solenoid) screen becomes clogged and must be cleaned out for water to flow. Follow the water hose at the back of the fridge from the top of the box to the little blue or red valve (solenoid) at the bottom of the fridge, or you may simply follow your fresh water line from your line tap to the fridge itself, turn that off and remove it. Now inspect and clear any obstructions you see on the screen. With a helper on the other end, have them turn your water tap on at the source to check for water flow using a cup or mop bucket to catch the water as it comes out. If all is well water flows and the screen is clean and you may now reattach the fresh water line. Now we test the solenoid. This test requires a standard carpenters nail and a block of wood. Placing the wood as close to the solenoid as possible, while keeping it flat and level, take the carpenters nail and place it as close to the water valve/solenoid as possible while standing it on it's head on the block of wood. When the solenoid trips the nail will fall over and you will hear it hit the floor. When that happens you should hear water flow into the ice maker. If no water flows, your solenoid is jammed and needs to be replaced.
Mar 13, 2010 | Refrigerators
Turned Whirpoll ED22PE off and moved to install new flooring. Put back to previous location, connected water and elect...would not make ice. Someone said it has a temp sensor and must be 10 deg b4 making...
If the water valve is leaking a bit, it will cause freezeup, as will a flow restriction. The 'water splashed inside freezer' sounds like leaky shut-off valve.
Sometimes those 'saddle pirecing' water shutoff valves get restricted, so you are not getting enough pressure.
Also, if you had things disconnected, a little bit of grit may be in the filter or shut-off valve, causing issues.
I would:
a) check the house water pressure, to make sure it's normal
b) check/clean/replace fridge water filter
c) inspect/replace saddle valve and look for kinked water feed line
d) backflush water out of fridge, if possible, and look at clean/inspect/replace water valve.
Although they do make add-on heater kits for water maker feed lines, your issue just sounds like a water flow issue...either a leaky valve or a flow restriction.
Nov 02, 2009 | Whirlpool GS6NBEXR Side by Side...
Not making ice unless I pour water in tray, water does not flow from small plastic line that feeds tray. I did clean screen at suppy line.
It could be the water valve or water switch in the icemaker. Now it doesnt call for water until the thermostat is satisfied.Now if you pour water and it goes thru and dumps into the bucket I would try to change the valve.
Sep 29, 2009 | U-Line Icemaker
Brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
Ice maker will not work
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Apr 01, 2009 | Frigidaire Optional Icemaker Kit
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
