Question about Philips Audio Players & Recorders
Philips HTR-5000 A/V receiver will not turn on.....
I have a Philips HTR-5000 A/V receiver that recently stopped working. It will not power on although it gets some power because the red LED light on the power button just blinks continuously along with a ''chirp'' or ''twittering'' sound coming from the inside of the unit. I removed the top of the unit and the sound is coming from the circuitboard. The sound and the LED blink is in sync. Could a component or something be making the sound and if so, which one? Please help.....Thanks
    Top Expert:
  • Philips Master
  • 45,065 Answers
Probably power supply failure
Posted on Nov 03, 2016
SOURCE: Marantz SR6001 AV Surround Receiver - Blinking Standy Light
Try pressing the power, and multi speaker button at the same time. But first turn the unit off...then press the above buttons at the same time...This is for the SR6001... GH
Posted on Apr 22, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
Foxyjay
  • 13 Answers
SOURCE: blinking red power light
I think Denon designed in a "bug" as mine just "went east" today
Posted on Jul 22, 2008
SOURCE: Power on problem
Well this helped me find the relay but I found that after i pulled it off the board that it has some corosion around the metal prongs that hold it to the board. Could not get the relay open to do what is posted above , tryed opening it several times. Not sure if you are supposed to open it but could someone let me know. I am scraping around the prongs to get the corosion off hoping it will help but might just replace it alltogether. Further info on how to open the relay to do what is posted would help, I would appreciate any help, plzzzzz! :)
Posted on Aug 28, 2008
SOURCE: Pioneer power LED is Blinking
If that didn't work, with the power off try holding Tune + and Auto surround/stream direct buttons for a few seconds to reset the protection circuits. Make sure to keep 8" of empty space above the unit for air, as overheating can cause this problem. If it fails again, there could be bigger problems, so get it checked
Posted on Jan 24, 2010
Yamaha receiver HTR-3064 turn on but go to protection mode no sound
Htr-3064 reset power on - Fixya
www.fixya.com/support/t22761844-htr_3064_reset_power
Jan 8, 2014 - htr-3064 reset power on My Yamaha HTR-3064 will not turn on at all. ... 'straight' button as you power up to go into "advanced" menu (under DILLIGAF's post.) ... Not sure if I needed to unplug everything, but I was about to .... How do I turn ofprotection mode on my optimus sta 3200 receiver digital No sound.
Turns on but no sound - Fixya
Yamaha HTR-5460 Repair Brief.mpg - YouTube? 15:04https://www.youtube.com/watch?v=keaq2F4LrU4Feb 5, 2011 - Uploaded by Mark ZachariasThe Multimeter Junkie fixes an HTR-5460 with protectionproblems. ... Yamaha RX-V459DAB - Not powering ...Missing: 3064Yamaha HTR-5640 AV-Recei
Dec 21, 2015 | Yamaha Audio Players & Recorders
Tip
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
on Feb 10, 2009 | Yamaha HTR-5650 Receiver
Hi! I bought PS3 and I have good old Philips HTR 5000. I have connected HTR 5000 to my PS3 with optical cable, so I'm thinking, do I choose Linear PCM, Bitstream (Direct) or Bitstream (Mix) from my...
There is no single answer. It would depend on the nature of your source digital audio (duh). Try them all. I use many non-standard digital modes on music, for example, and they all yield sonic differences with varying degrees of improvement or novelty.
Apr 14, 2011 | Philips HTR-5000 Theater System
Trying to find a universal remote code for philips HTR 5000 receiver.
Don't waste your time, spend on Logitech Harmony one, which will work and you can program other devices as well.
Mar 27, 2011 | Philips HTR-5000 Theater System
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Our HTR-5660 is about 5 years old. Recently it
I solved the problem by ensuring the Impedence selector was either all the way to the left or all the way to the right, as instructed in the manual.
Jan 19, 2010 | Yamaha HTR-5660 Receiver
I recently purchased a yamaha YST-FSW100 subwoofer and plugged connected it to my HTR 6140. Subs woulld not work. How will Iknow which devise is not working?
Turn the sub on, then touch the end of the sub lead when you take it out of the back of the amp..it should buzz to show the sub is ok . If the sub is ok then go through the setup on the Yamaha and tell it there is a sub connected in the speaker setup.
Nov 07, 2009 | Yamaha HTR-6140 Receiver
Cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
Dec 28, 2008 | Yamaha HTR-6130 Receiver
Yamaha HTR-5240 no sound from main speakers
check and see if there is a a/b,a+b setting for speakers make sure its set to a
Jan 06, 2008 | Yamaha HTR-5240 Receiver
415 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
