Air condition motor need to hook up.
I have an Emerson Motor with Blue, Black and Red wires coming out of it. P/n K55HXonF 2373. Its a 4 hp motor dual speed. I want to connect it to 110, how can I do this?
  • chopped50for Jun 28, 2009
    Motor is 230v 60 Hz 1100/800 rpm motor if that adds any light
  • 867 Answers
Seems to be a 220 motor, so you cannot use 110 anyway
Posted on Jun 27, 2009
  • bozcro
    bozcro Jun 28, 2009
    you have to use 220 to power this motor, you can get a licensed electrician to wire you a 220 outlet from your fuse box
Iam replacng my home a/c blower motor. My unit hasa red a black and a white wire. My new motor has a black wire a blue wire a red wire and a yellow wire. I need to know which color wire goes to which
On the original motor, red was low speed, black was high speed and white was common. The new motor should either have a diagram on the side of it or within the box for verification, but the black SHOULD also be high speed and the red wire SHOULD be low speed , the blue wire SHOULD be medium and the yellow SHOULD be common. However, you MUST verify those connections on the wiring diagram provided with the new motor before you connect or you will probably let out the MAJIC SMOKE !!! The speed you decide not to utilize can just be taped off and zip tied to the bundle.
You made no comment about two brown wires, and if either motor has two browns, they go to the run capacitor.
Dec 23, 2014 | GE Heating & Cooling
Have a 230 volt fan motor. no diagram. its a emerson k55hxbmj-1121 1/6 hp
On a 220-230 V ac motor black and white are both hot legs On the lable on the side of the motor there is a diagram that tells you what wires go where. The 2 brown go to a capacitor. if there is a red and blue thoes are speed taps. You would use either in place of the black for slow or Med speed.
Aug 31, 2014 | Heating & Cooling
Blower motor installation
just check the wiring diagram and connect the two wires for the desired speed and put a wire nut one the third one.
Aug 08, 2014 | Emerson NEW A/C Fan MOTOR 1/4 1/6 1/8 HP,...
Old motor wires are numbered new motor wires are colored this is a 1/2 hp reversing motor for a overhead door
Single Phase Terminal Markings Identified By Color: (NEMA Standards) 1-Blue 5-Black P1-No color assigned 2-White 6-No color assigned P2-Brown 3-Orange 7-No color assigned 4-Yellow 8-Red
Mar 02, 2014 | Computers & Internet
I am installing a Mars 1/3 hp fan motor. It has a black wire,red wire, blue wire, yellow wire and (2) brown wire that go to a capacitor. May Furnace has Black power wire, red wire (speed) and white common....
Hello, Typically your common wire will be white, high speed- black, medium speed- yellow, medium low-blue, red- low. The motor could still run for a short time if it was wired wrong but will either trip a breaker or go off on it;s overload when it's gets hot.
Feb 26, 2011 | Heating & Cooling
Replaced old Ge 1/2hp fan blower motor w/ emerson motor wire not the same couldnot get to work. motors has blk,blue,red,white/brown, brownw/white strip/furance wires are blk,red,white could some tell me...
I am assuming you still have both motors, if you look on the side they will show you what wires go to what. Your Brown/white should be for the capicator. blk should be blk, blu might be white and red be red. I couldn't really say for certain with out looking at the diagram on the side of the motors. I hope this helped Tim
Aug 02, 2010 | Heating & Cooling
Changed out blower motor on elect furnace.the old motor had three wires one fed the compaster.new motor is revirsable has purple wire,red,blue,black.hooked up purple 1st phase,red for high 2nd phase. is...
hmmm . you better check on that before firing it up ... normally the colored wires are for different speeds .. only one speed can be connected at a time .. usually the high speed winding is used for air conditioning and a lower speed winding is selected by a relay for heating .. ... the way the capacitor is hooked up determines which way the motor will turn .. your old motor with just 3 wires was probably a single speed motor .. normally the black wire will be connected permanantly to one phase .. the other phase then goes to the selected speed winding (color of wire) .. one goes to the starting capacitor . the others even if not connected will be hot electrically so need wire nuts to prevent shorts ..
Jan 03, 2010 | Dayton (2C373) Fan
Wiring Diagram for a Emerson Motor in a Tempstar Central A/C
EMERSON 1/4 HP MOTOR 5 WIRES BLACK BLUE BROWN WHITE RED LOST MY DIAGRAM 115V1075 RPM 3 SPD HOW DO I WIRE IT TO THE COMPRESSOR
Sep 26, 2008 | Emerson Heating & Cooling
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
