Question about Garden
Does not respond to increased trigger presure
    Scholar:
  • 48 Answers
Bring it by my shop, I have a trigger that it will respond to without question.
Seriously, that was a question? About what?
Posted on Jun 28, 2009
What makes machine shut off after 15-20 pounds of pressure how do I get it to run up to 100pounds of presure
Hi Tony:
There should be a pressure controlled switch.
It should have an adjustment, often with a lock nut.
If you back off the lock nut, the centre can be screwed inwards to increase the "trigger" pressure.
Your unit may not be exactly as I describe, but the principle will be the same.
Hope this helps.
Nov 14, 2015 | Air Tools & Compressors
Using presure washer - released trigger on nozzle could hear motor loadig up then a pop like something rubber bursting and water poured from under side and very little presure at nozzle help please.
It would seem that your bypass/unloader valve has failed.This will happen if a unit has been sitting and corrosion builds up in the pump head.
The valve failing has caused it to pop an o-ring or seal, it will require to be stripped down and repaired.
Brad
Jul 18, 2014 | Honda Garden
Why is my unloader valve opening and closing when I'm not squeezing the trigger\
thats exaclty what a unloader valve does it unloads the pump when the trigger on wand is not depressed , it should however reseat and close off when trigger is pressed giving full presure to wand tip
May 11, 2014 | Northstar Professional Series Pressure...
Does anyone have a answer as to why all of a sudden theres no water and presure coming out of my jet washer
If there is no water from you power washer it is because the is no water going in. Check fitting is connected properly. When you pull the trigger and the machine is not running you should get water coming out of the nozzle That shows that water from the tap is passing through the machine. As to no pressure that will be a fault in the regulator valve that is not reacting to the trigger setting and allowing the pump to build up pressure. It is still reading as if you haven't pulled the trigger
Feb 24, 2013 | Honda GCV160 Engine
ENGINE RUNS FINE WHILE HOLDING THE WAND TRIGGER BUT , WHEN I RELEASE THE TRIGGER THE ENGINE STALLS OUT
you have a faulty presure relief valve. it is building up presure and killing the engine.
Jun 16, 2011 | Devilbliss DeVILBISS Devap DVH2600...
The moter on my electric presure wash turns on and off but never really starts
if its when your trigger is on and it surges you might have a blocked nozzle, if its when you let your trigger off and it surges you have a leak on the high pressure side of the pump, but we need more information on what brand/model etc. best to take it to an authorised dealer of your brand
Sep 24, 2009 | Garden
I can't get the master to print to the edges on GR1700 Risograph
By increasing the presure on the presure roller.If you can give me the model I can help you more
Aug 18, 2009 | Office Equipment & Supplies
Pressure washer hesitates, does not start. Unable
get someone to keep the trigger pulled while you try to start it , its probably got presure trapped between the trigger and the pump.
alternatively turn off the water to the pump, pull the trigger to release any pressure trapped.
start the engine , allow engine to warm up, increase revs on engine then turn on water, should be ok then. Unless you have a problem with the engine that is!
Jul 21, 2009 | Briggs & Stratton Garden
Hi i have inherited a karcher kb9040.it has only been used 4 or 5 times so i dont realy know how it should sound when. water is suplied to it it surges when you pull the trigger you only get the presure of...
hi there!
when you got as good as pipe pressure,you need to accelerate the speed motor to have a good pressurise water for your purpose,the pressure washer has a surge regulating valve as you trigger water gun the pressure blow up,as long
as you pull the trigger on the pressure build up pressure it has also equipt with pressure switch to regulate pressure and for safety purpose.you can also adjust the nozzle by rotating gradually to slim the pressure water out put.have a nice day,don't forget to rate me.thank's
Apr 20, 2009 | Garden
Leisure 90 classic
We being US based have no idea on what is in UK SORRY. but quite possibly it has natural gas orfices in it and needs LPG ones
Nov 18, 2017 | Hotpoint RGB526 Gas Kitchen Range
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
