Cannot get tv to scan digital stations. I have a
Cannot get tv to scan digital stations. I have a digital rooftop antennae attached to tv and I have also attached the converter box. Television will scan regular channels and stop on channel w/digital info. Sometimes the screen shows that I have ''no signal''. I have also moved tv to a different location where another tv is working. Still nothing! Seems like TV doesn't have digital capability. How can that be on a tv that is fairly new?
    Problem Solver:
  • 20 Answers
Test test 18:30
test test test 18:31s rthsr thsty 3456234
Posted on Jul 07, 2009
How do I scan a Craig LED TV for digital channels?
If it is fairly new it should be able to scan for Digital Stations. Connect it to an antenna that you know works on another TV and you can go to www.TVFOOL.com and it will tell you what stations are available at your address and what type of antenna is needed.
Dec 03, 2014 | Craig Televison & Video
Does this product have a built in digital to analog converter?
This tv incorperates a full digital PLL tuner. It does not need a digital to analog coverter since analog signals is no longer used. All tv stations now broadcast with digital signal. It will receive local broadcast stations just connect a goood quality antenna to the tv. You will need to do a scan and the tv will store all of your local broadcasting stations within range. An outdoor antenna works best for digital signals.
Sep 13, 2012 | Samsung LN32B460 32 in. LCD HDTV
I have a symphonic wf32L6 and i dont want to buy a digital adapter box, doesnt this tv have a digital tuner
Yes it has a Digital Tuner/ HDTV Tuner. Go into the setup menu of the TV and do a digital channel scan. If you still have an issue, post a reply/comment and I will help you further.
Jun 01, 2011 | Televison & Video
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
A large portion of tv screen covered by black
you need to get either a better rooftop antenna or an amplified adapter . it is undetermine which stations will come in for digital.
Feb 22, 2010 | Televison & Video
I tried connecting an RCA antenna to get digital stations, but the tv didn't recognize any of the digital stations on the scan. Any ideas?
its very difficult to get digital stations if youre using an indoor standard antenna , unless you have a SPECIAL DIGITAL ANTENNA for indoors , but I suggest an outdoor antenna , the higher ,the better to locate digital stations , AJ
Nov 30, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
Are there any boxes that don't require 'autoscan' for setup?
How to connect a motorola DCH3416 to a computer?
Feb 19, 2009 | Televison & Video
Piture breaks up
Usually rooftop antennas yield the best reception, but if it's old maybe it's rusted or the cables need replacing perhaps. With digital programming, it's either it comes in great or you don't get a pic at all unlike analog which will allow snowy images and bad reception to come in.
Nov 04, 2008 | Insignia Digital-to-Analog Converter for...
Digital signal conversion
If you have cable TV, satellite TV, or FIOS, the coupon eligible converter boxes aren't needed and aren't useful with those services.
They gov't coupon converter boxes are only good for reception with a regular TV antenna or rabbit ears.
According to the specs on epinions.com, no, this TV does not have a digital tuner. So, if you use a rooftop TV antenna (not satellite dish) or an indoor TV antenna, you WILL need an ATSC to NTSC converter box. You need not wait until next year, however, as most U.S. TV stations are also broadcasting digital (ATSC) now.
Feb 23, 2008 | Sanyo DS27820 27" TV
Televison & Video Logo
236 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
