Question about ZT Group CISNET A7050 PC Desktop
Have a issue trying to remove a security thing that was put on my cisnet comp I am unable to access add/remove do a system restore or even download a removal tool such as spyware to remove the program it allows the first part of the download but then blocks any further action by saying it is infected The name is Security Systems and yea I wasn't paying attention. Also have tried to start in safe mode but f8 doesn't work and neither did msconfig so is there one more way to start in safe mode?
  • 334 Answers
Hey there, this should be simple. You just have a rogue program that took it upon itself to install on your pc. Got to the following link download malwarebytes, save it on your desktop. Restart in safe mode, install malwarebytes and run a full scan. this should clean you righ up good luck, let me know if you need anything else
seth
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-8022_4-10804572&ontId=8022_4&spi=8d40fa64976355f9432d8bc8d663aadd&lop=link&ltype=dl_dlnow&pid=11039785&mfgId=6290020&merId=6290020&pguid=cRpn0goPjF0AABuzujIAAACr&destUrl=http%3A%2F%2Fdownload.cnet.com%2F3001-8022_4-10804572.html%3Fspi%3D8d40fa64976355f9432d8bc8d663aadd%26part%3Ddl-10804572
Posted on Jun 27, 2009
Cisnet desktop pc will not boot up
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell
you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs
accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
if the system restore fails
test all power and data leads that attach to your hard drive IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty
computers need data and power to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty power connection or faulty fan lead can cause you problems
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer ram modules make sure they are securely seated
on some motherboards cmos batteries are soldered in
hope this helps
Jul 20, 2012 | ZT Group Cisnet PC Desktop
May 25th my CISnet computer would not start Windows, a file was missing. I did not have my Windows CD so I let the CISnet do the Restore. Can I undo the change after my CISnet computer restore to original...
Try the following;
1. Press "Start" on your Cisnet computer's desktop screen. Scroll up to "Accessories," then hover over "System Tools." Click on "System Restore."
2. Click the option that allows you to select a different restore point, rather than using the default restore point. The program will display a calendar.
3. Select a specific point to restore your Cisnet computer to by choosing a date from the calendar display. Click the "Next" button to confirm, then click "Finish" to close out system restore. Your Cisnet computer will restart and open with the selected settings.
Be sure that you do not unplug your Cisnet computer while running system restore because it will need sufficient battery life to complete the program.
Jun 02, 2011 | Computers & Internet
My Toshiba PH3100U-1EXB external hard drive (1tb) is not being recognized properly. Windows detects the device but unable to install it. This issue started after trying to install the toshiba sleep removal...
Hello stxman, the best thing to do is a "System Restore." "Follow these instructions carefully!" The first thing you want to do is click on the "Start Button." paul7of9_50.jpg Next, click on "All Programs." Scroll to find "Accessories." Now; select the "System Tools." paul7of9_51.jpg"You will see in the next window that open, "System Restore." !Important, Once you click on the System Restore "shortcut." "It will start to look for the "Last known time of a change in your computer." ie. Toshiba Sleep Removal! The System Restore, can take as long as a 1/2 an hour to run! So; "Be Patient!" !Warning: "Do not try to do any type of work, don't even touch the keyboard for any reason." Once, the System Restore find: The correct {Date and Time}, of the event. paul7of9_53.jpg Coose the [Date] closest to the time of the 'occurrence'. ie. Installed [Toshiba Sleep Removal Tool]. !Warning: There will be a message: "Do not to do any type of 'work, or have applications' running' on the Computer. paul7of9_52.jpg "The System Restore will "run" for awhile; denpending on 'how far back the restore need to 'search'! The computer will then "Shutdown and Restart." Lo-gin if you have to; but! Do not touch the Keyboard once the Desktop window open. "Because "System Restore" is still running. Wait; until there is a message letting you know the {Restore of your System}, was successful!
"Please let me know if you 'need' further assistance, or the 'solution' helped? "By posting a 'Comment" or 'Rating' the solution. Thank you; your 'response' is important to me!"
paul7of9
Feb 26, 2011 | Toshiba PH3100U1EXB 10TB Desktop External ...
Start up and desktop icons missing
This could happen due to various reasons like :
1. Any recent update done.
2) Virus infected
3) Windows missing/corrupted files.
There are several steps to resolve the issue.
Try one after another and check if that fixes the issue.
Step 1
Try this Fix
Click on the Download link and install the Fix No. 195 ( Restore Desktop Icons and Taskbar )
Download Link
Step 2
Press CTRL-ALT-DEL to bring Task Manager.
Click on New Task and type appwiz.cpl and click OK
This will re-run add/remove programs.
Remove/Uninstall all new program you installed before having this problem, Also remove the Windows XP Hotfix
Restart your PC.
The access to the taskbar , icons will all come back and Install a new Antivirus.
Step 3
If None of the above steps work, try a System Restore to previous date
Click START - All Programs - ACCSESSORIES - System Tool - System Restore
Choose the date before the system started giving trouble. ( The Date will be in bold ( highlighted ) which indicates the system can be restored to that date with all the settings on that date )
*Note : Doing system restore will uninstall any software/program you have installed from the date you choose the system restore till current date, However it will not delete any files created )
Hope this is helpful.
Nov 10, 2010 | Dell Dimension 9200 PC Desktop
Warning that my computer may be infected/ can't access internet
Possibly security setting issue. In your Internet Explorer, click Tools->Internet Options. Click Security tab, then click "Reset all zone to default level".
May 30, 2010 | Compaq Presario 5000 PC Desktop
My computer freezes when i plug in to the usb with
It sounds like a defect in the USB circuit on your system board. (This assumes that the problem occurs with any USB port). You might be able to add a PCMCIA board to add USB funcionality without replacing the system board to save money.
Apr 25, 2010 | ZT Group Cisnet T2060 Notebook Computer
Win32 app error for every application opened. the last thing i downloaded was updates for my hp laptop after stating it had updates available. i can't go to anything , tried accessing control panel to...
Do a system restore. start>all programs>accessories>system tools>system restore.
or in vista: just type system in the start search and click on system restore.
Sep 22, 2009 | Dell Inspiron 1420 Notebook
Cannot access secure websites PLEASE HELP!!
Maybe your network at work is blocking it. Check with your computer guru at work.
Aug 09, 2009 | Sony VAIO VGN-NS240E/W Notebook
I to am unable to download anything from the internet or view any video's. Tried to update or reinstall Adobe flash player and it will not download from the Adobe site or the Microsoft site. Cannot view...
Check for Highjackers, Malware, Viruses, or anything else that could have screwed with the OS. Sounds to me you had something wrong with your computer before SP3 was added. Personally if it was me I would back up all my data to a CD or thumb drive and wipe the computer clean and start over. You could try System Restore and remove SP3 but that only bandaids the issue.
Have a good one.
ArmyMason
Feb 26, 2009 | Microsoft Windows XP Professional
ZT Group CISNET A7050 PC Desktop Logo
55 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
Jose Pino
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
