Question about Lexmark Optra T610 Laser Printer
OPTRA T 610 Lexmark printer.
On the left hand side of the printer where there are two wheels, (white) that are being held together with what appears to be a plastic brace. This brace is cracked and not allowing printing to be done. Do you know where I can obtain this black piece of plastic?
Thank you.
Dawn 312-771-2157
  • 43 Answers
Re: OPTRA T 610 Lexmark printer.
It sounds like you are describing the pick arm or autocompensator. It also sounds like you have the printer turned on its right side for that to be on the left. The part you are looking for is part # 99A1056 for the Optra T610.
Posted on Dec 01, 2007
0 characters
3 Points
I want to change language - lexmark optra t610 printer
You can change the language on your Lexmark Optra T610 by pressing right arrow Menu button 6 times -> select Printer Language (first option to appear), hit Select -> select preferred language, hit Select button to save.
Hope this helps. Thanks.
Nov 10, 2010 | Lexmark Optra T610 Laser Printer
How to install a Lexmark Optra E310 printer without the software
This is an older printer. Lexmark support has driver files available for this model, but the most recent one appears to be for XP.
If your operating system is newer than XP, this printer may need to operate with the driver that you can auto-download from Windows Update.
Lexmark Optra E310 Downloads
On the tabs, click the one for your OS. Download the correct driver file for your system.
Mar 09, 2010 | Lexmark Optra E310 Laser Printer
Big noise
the only ribbon that i know of in these printers is the ribbon on the thernistor for the fuser if this came out then the fuser as melted together. pull the fuser out and try turning it by hand i think you will find that the hotroll gear has broken andthe 2 rollers are fused together. replace the fuser
Dec 02, 2009 | Lexmark Optra M410 Laser Printer
Lexmark laser printer leaving a white streak 2-3
take a q-tip and clean the scanner window. this is located in a 3/16' opening on the roof of the printer cavity it will be about 8inchs long. pull the toner cartridge and feel with your fingers on the roof of the cavity this will be located above the transfer roller slightly towards the front of the printer. white lines like this mean the laser is being blocked usually by a bit of toner or other dirt of some kind
Nov 30, 2009 | Lexmark E232 Laser Printer
Hello, Leo.
Here are the steps:
  1. Turn the printer power off (O).
  2. Press and hold Select and Return together.
  3. Turn on the printer.
  4. Release the buttons once Performing Self Test appears on the operator panel display.
  5. The printer performs its normal POR cycle, then prints one copy of the Print Quality Test pages.
Hope this helps.
Oct 15, 2009 | Lexmark Optra S 1855 Laser Printer
Ongeldige engine code
try flashing firmware, or replace engine board
Feb 27, 2009 | Lexmark Optra T610 Laser Printer
Lexmark printer CD-ROM
I have a Lexmark Optra E310 printer that works fine with the following Vista printer drivers:
Lexmark Optra E312 (MS)
Lexmark Optra E312 PS.
Aug 26, 2008 | Lexmark Optra E310 Laser Printer
Optra T614 printer
i had the same problem and it went away after i removed the main circuit board and reinstalled it. (left side of the machine)
Apr 03, 2008 | Lexmark Optra T614 Laser Printer
Poor print
Try running a calibration on the printer.
Also try running clean heads function on the printer if it can do so.
Most printers have those options under maintenance.
Dec 12, 2007 | Lexmark Optra S 1625 Laser Printer
Lexmark Optra T610 Laser Printer Logo
80 people viewed this question
Top Lexmark Printers & Copiers Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Printer and Copier Expert? Answer questions, earn points and help others
