Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
"craftsman 19.5 Hp Hydrastatic trans loses power after warming up
"after hydrastatic transaxle warms up it starts whining and will not pull me up a hill. What goes? I have replaced the drive belt.
According to my owners manual it is a sealed transmission . The fan blades on top of the trans are clean. Any suggestions would be
appreciated......
4 Suggested Answers
  • 246 Answers
SOURCE: craftsman 20.5 hp. auto trans.lawn tractor loss of drive power
Hello:
>>You can View a Breakdown/IPL of
this Engine at this Site Addy,
http://www.outdoordistributors.com/
and Select the H. Then Select Hydro-
Gear. Then Select Don't have Part
Numbers. Then Enter the Model
Numbers 319-0650. Then Select your
Model and Download the File for
Online Viewing.
From your Description it Sounds like the Internal Pump is Worn and is Loosing Pressure as the Unit Heats Up and the Components Expand from the Heat.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
mickey813
  • 472 Answers
SOURCE: hydrastatic drive trans grinds in revers stalls
SOUNDS LIKE THE IN PUT SHAFT ON THE TRANS IS STRIPED OUT
Posted on Oct 20, 2009
  • 6468 Answers
SOURCE: Sears garden tractor hydrostatic transmission whines and can't go up hill. What's the fix???
is the signs of oil leaks on the rear axle and the fluid level is low
Posted on May 28, 2012
Bypass valve does not dissengage hydrastatic trans how to fix prob??
Best solution www.reliable-store.com has books on every vehicle and also how to service/repair it.
service/repair/owner's/maintenance manual with
parts info, fuse box, gear box, PCV, torque specs,coiling, wiring diagrams, electrical diagrams, fuse diagrams, error codes, etc everything
Worth it
Mar 15, 2018 | Cars & Trucks
Mower stuck in gear
I would say you have a problem in the hydrastatic transmission itself,and that could be a number of different things and hard for you to fix yourself,it would be best to have professionally checked out.
Mar 24, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
What fluid is used for the Hydrastatic transmission on a Yamaha YT3600
best advice is to contact the dealer and ask for the type of oil you are to use.
Apr 21, 2013 | Cars & Trucks
My hydrastatic rear end quits pulling when hot just growls let cool start back pulling
Hi, remove the battery and battery carrier and clean all grass and debris from the hydro cooling fins and fan. refit battery and carrier. Regards Phil.
Jun 12, 2012 | Husqvarna Yard Tractor
Hydrastatic transmission not working right it is slow;
first check the belt tension then the fluid level if you can
Apr 10, 2012 | Garden
I have a 42 inch craftmas mower and the fluid is leaking from the hydrastatic area, can I replace it with transmission fluid.
If you transaxle is leaking badly adding oil may not help long term,if you remove the back hitch plate there is a allen wrench plug or a rubber vent hose, you can add oil there,measure down from the top of transaxle and fill to within 1.5 inch of the top,always allow 1.5 in of air space in top to allow for expansion. Add amsoil or mobil 1 synthetic motor oil 15w-50 or 20w-50. Do not use transmission fluid or hydraulic oil.
Jul 20, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My G100 hydrastatic does not work longgoes about 20 feet then won't go up any kind of grade
Check the trans oil if it is full your trans is bad and is a expensive fix.
Sam
Jul 11, 2009 | John Deere Garden
HYDRASTATIC TRANSMISSION DOESN'T MOVE
Far as I know the warranties are not transferable. Some hydrastatic transmission fluid can be checked by removing the battery and underneath there is a place to put the fluid and to check it. But not all models or makes gives you this option.
Jun 22, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
879 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
