Question about Brother MFC 9600 All-In-One Laser Printer
9600 just beeps when I plug it in
When I plug my MFC 9600 in to power (no USB or phone connections), I get a sound like a phone ring out of the right side of it. The keys and LCD are both dead. Sounds like a low-level memory error or something. Any ideas?
  • gcrocker Nov 06, 2007
    No go on the * 2 8 6 4, and no keys seem stuck. Is there a CMOS battery I can pull to force a ram reset? I'm happy to open the machine up if there's any reason to think it'll help.
    Cool, thanks!
  • Brother Master
  • 1,113 Answers
You could try ram clear, but I think you need to replace main p.c.b. ram clear is menu * 2 8 6 4 (must be done supa quick, practice till you do it rapid) then 01 start, but you might have trouble without keypad being operational, no easy fix, also check that no buttons are stuck down.
Posted on Nov 06, 2007
  • Soulvisitor
    Soulvisitor Nov 06, 2007
    Not worth pulling battery, needs Main P.c.B.
Dialtone but no ring only beep
Sounds like its either going offline maybe checking the outlet and the cord that plugs into the base. It may also be the battery needs replacing,it has been run down and charged again too many times.it may hold enough for a dial tone but not enuff to even ring,just beep I stead
Jul 01, 2013 | Lands Phones
Cordless Extension handset (non-color) screen remains blank and does not connect to Multi Function Printer.
Hi, the handset is not registered with base, to register please follow this process:
1. On handset press Menu/OK.
2. Press cursor up or down to choose "Register HS", then press Menu/OK.
3. Press Menu, 0, 6 on the control panel of base unit (MFP)
4. Press OK on the control panel of MFP.
You should hear one long beep when the handset is registered correctly. If not (three short beeps) repeat steps from 2 to 4.
Aug 02, 2012 | Brother BCL-D10 - Cordless extension...
My 9600 just prints pages and pages of numbers and symbols when I send anything to print
Sounds to me like you are using an incorrect printer driver, or corrupted settings. Please disconnect the printer USB or LPT cable the under control panel >>Printers , uninstall your printers. Surf to the brother website and download a new driver for your printer and Operating system version Vista / XP ect. then install the new driver software and reconnect the printer. Kind of a pain, but it will fix it. Take care
Aug 29, 2010 | Brother MFC 9600 All-In-One Laser Printer
When I plug the printer into the phone jack the house phone goes dead. The phone line is an ATT Ring Master, Distinctive ring is on on the printer
Are you sure you're plugging into the phone jack on the printer? The network cable jack will hold a phone jack.
The network cable jack is (from the front of the machine) on the left side, right above the USB port. The phone lines are in back, top center. The incoming line should go into the jack labeled 'Line', which I think is the one on the right when you're looking at them.
Jan 30, 2010 | Brother MFC-9840CDW Laser Printer
Laser MFC 9600 IS PRINTING BLACK LINES ON COPIES
Take out the drum and toner and slide the tab on the top right cover 15 times. Also clean the two Scanner glass windows under the cover.
Jan 06, 2010 | Brother MFC 9600 All-In-One Laser Printer
How to change fax speed from14.4 to 9600
The machine does this automatically on connection. It negotiates a reliable connection speed with the recipient machine and then transmits data. If in encounters an error repeatedly it will negotiate the speed down even further until the data can be sent successfully. However the following menu setup option may help
Main MenuFaxSetup SendOverseas ModeOn will change the speed down to 9600 max and negotiate downwards if required.
Oct 30, 2009 | Brother Multi-Function Center MFC-240C...
My mfc 9600 shows machine error 76 can you explain the fault
That tells you either the wires to the fuser are un-plugged, or the fuser is burned out. Most likely you need a new fuser.
Sep 10, 2009 | Brother MFC 9600 All-In-One Laser Printer
Brother MFC 9600 won't pull paper from tray
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 07, 2009 | Brother MFC 9600 All-In-One Laser Printer
Manual
Hi - You can download the manual from the link underlined in blue below:
MFC 9600
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Brother MFC 9600 All-In-One Laser Printer
Fax won't answer
UNPLUG FROM THE POWER. PRESS AND HOLD # & 9 AND AS U HOLDING PLUG THE POWER BACK TO IT, AND THEN REALEASE WHEN IS START TO POWER ON.
May 14, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 9600 All-In-One Laser Printer Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
