Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
It's snowing in my freezer!
I have a kichenaid superba KSRG22FKSS15 side by side refrigerator. It started to snow in my freezer near the ice maker and the refrigerator won't get cold enough to keep food fresh. I never replaced the water filter..could that be the problem? Can I fix this on my own? Thank you.
Do you ahve the answer for the above problem, and can it be fixed? If so how?
Posted on Dec 26, 2009
  • 232 Answers
It's not the filter. is there frost on the inside lower back of the freezer. or is it around the edge of the door are your ice cubes fuzzy can you here the fan running in the freezer
Posted on Jun 28, 2009
  • bill williams
    bill williams Dec 25, 2009
    are the door gaskets in good shape
Kichenaid superba architect is warm up top
Check your freon level you can buy piercing valve for about 5 dollars low side pressure should be 11or12 on 134a after about 5 years I have found it sometimes seeps out of compressor
Sep 30, 2012 | KitchenAid Superba Architect KSCS25INSS...
Side by side refrigerator will not cool and ice maker does not work although the freezer is cooling. It is 5 years old.
check damper operations. blockage of air flow. check make sure no ice build up in back panel of freezer side like a snow pattern
Feb 07, 2010 | Refrigerators
Ice despencer opening keeps freezing and wont dispence
you have a bad door seal. replacement is better than repair. warm moist air is getting in and the condensation is freezing.
Nov 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice Maker not working in Kitchen Aid Superba. Light is blinking constantly on right side wall of freezer. Is this normal?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
44
Sep 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Snow building up around ice maker opening
Check to make sure the dispenser door is closing all the way and I mean ALL the way.
GE has had issues with the solenoid rusting out on those units and not letting the door close all the way.
Sep 03, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer suddenly is creating mounds of freezer "fluff"
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Sea Breeze
Aug 20, 2009 | KitchenAid KSRS25ILSS Side by Side...
SNOW FORMING IN FREEZER
Could be a number of things. Is the fan running in the freezer section, are the door gaskets sealing completely, even on the bottom of the doors? Could be a defrost issure where the thermotat is allowing it to over heat during defrost and the the cooling cycle starts after defrost and forms the ice an snow from the moisture in the unit.
Dec 30, 2017 | GE Profile 21.6 cu. ft. Side-by-Side...
Snows inside freezeer compartment of side by side
You actually have 2 problems here.
One the ice maker shutoff is defective. REPAIR is to replace the ice maker.
Two (snow) is a loose door seal, Outside air entering the freezer.
Feb 20, 2009 | Kenmore Refrigerators
Ice maker not working at all
We defrosted ours and it came back 2 life
Sep 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer is producing"snow" and freezer burning everything
AFTER A DEFROST,HAVE A GOOD LOOK AT THE DOOR RUBBER. IT MUST BE 100% SEALED FOR A FREEZER. (SHOULD ALSO HEAR A SLIGHT VACUME WHEN DOOR IS SHUT WHEN UP NTO TEMP).ALSO MAKE SURE MOTOR IS SWITCHING OFF AT +/- 20C (TEMP).IF ALLOWED TO RUN CONTINUOUSLY TEMP WILL PULL DOWN TO CREATE EXCESS FROST.
Jul 07, 2007 | Whirlpool ED2FHEXN Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
402 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
