Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
725r trimmer 31cc curve shaft gas trimmer tying to replace all gas lines correctly along with the primer
  • 122 Answers
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Ryobi 31cc 18'' 790r ez has no power
You have done just about all you can do with this machine give up and buy a new one
Jul 08, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a ryobi 31cc straight shaft with all the attachments. I am replacing the fuel line and need a schematic of what goes where. There are two holes under the tank reservoir and one has nothing attached...
The second hole is for the carburator return line(& primer line). Your correct their is nothing to attach it to. The line itself self seals the hole. If you inspect the old line you will see that where the line fits the hole the upper part & lower part were slightly larger in diameter. This enabled the line to seal itself in the hole when installed. If you have to replace the line, purchase a rubber washer and plastic cement and cement the line to the outside, leave about 1/4 of inch of line inside the tank. Try to buy tubing that is slightly larger then the whole which I belive is 1/8"OD. The other line is fuel supply it will have small white ring to attach the tubing to on the fuel tank.
May 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a ryoby 31cc weed eater I need a diagrm on the corect posision of fuel lines
Typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
Typical fuel line routing is:
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replaced gas lines on ryobi 31ccweedeater. my have lines crossed. will not crank.
One fuel line (the one with the fuel filter in the end of it), comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to the top fitting on carburator. That should be the correct fuel line routing. Hope this helped and best wishes.
Aug 28, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
725r trimmer
You can buy new Line to re-spool on your existing head
Aug 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My ryobi 31cc 15" 700r won't start
You need to push the primer button 10 times or so (the button at the top of the speed control) to get the gass pumped up into the system again. Likely gas not getting through the line yet. Takes awhile.
May 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
555 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
