Question about Windchaser FTR163 SensorFan Stand (Pedestal)
My Windchaser fan model FTR184 does not work anymore - it did yesterday. The oscillator function still works but the fan doesn't come on. The red light indicating standby mode is lit. How do I get it out of standby mode? I do not have a remote.
  • william doiron Aug 13, 2011
    standby light on will not wory i have remote
  • Anonymous Mar 12, 2014
    Wind chaser fan ftr184 is on standby how do I get the fan out of stand by
I have a Windchaser fan mode FTR184 also and it is in the same indicator STANDBY mode and now it will not come on and we have the remote, how do you fix this?
Posted on Jul 12, 2009
Windchaser tower ceramic heater model/ cerc1lb
The oscillation mechanism has failed - a frequent problem with this type of heater.
Dec 04, 2016 | Windchaser Heating & Cooling
Looking for replacement parts for Windchaser fan
You can take plumbers tape and wrap about 5 to 8 turns around the shaft threads and put blade on and cap. (Plumbers tape is white plastic tape on a roll with a pop off cap like medical tape comes in)
Remote? Maybe batteries.
Mar 15, 2015 | Windchaser Dryers
Wind chaser fan motor not working
Hard to find parts. Could contact manufacturer, but might not be cost effective.
Sep 21, 2012 | Windchaser Ionizer Tower Fan with Remote...
Blade broke
Look up zorotools.com and they should have a fan blade you can use it is most anything you can think of so maybe you can find the fan blade you need. Hope this will help Norm.
Aug 06, 2012 | Windchaser 3-way Oscillating Fan
All the leds turn on, incluiding the tower fan oscillate, But the essential doesn't work "it doesn't ventilate". What do you suggest?
check the fan if it is working.. if not ,can you hear any humming sound coming from the motor? if there is you need to remove the cover, then remove the circular fan,try to turn on the unit without a fan if the motor is running then just clean the rust in the bushing and shaft of fan by using sand paper. then put lubricant in the shaft and bushing(oil or wd40 or grease). make sure that you remember all the parts and the position of it.. good luck
Sep 13, 2010 | Windchaser WCUFLTI Tower Fan
Cooling fan not turning
You need to replace it.
Which cooling fan? There are sometimes several and the hardest one to replace is in the power supply. If you are handy with tools and don't mind the work, you can replace it yourself, otherwise you will have to get someone to do it for you.
Sep 10, 2009 | Windchaser 3-way Oscillating Fan
Humming noise from motor of oscillating fan.
Wd-40 is not a very good lubricant. It only lasts fror a few days and then dries up again. In order to get your fan working again, take some 3-in one oil and put a drop at the bearing side of each bearing top and bottom with the shaft upright. Spuin and tap the motor briskly with a small tack hammer or screw driver handle. This will impact and allow the oil to get into the bearings Keep tapping and turning until you feel it lighten up a spin freely. Turn it over and do the same thing again. I garuntee that all will be fine after this.
Sep 07, 2009 | Windchaser 3-way Oscillating Fan
My windchaser WCUFI wobbles so bad I think it's about to come off
Literally fixed this exact problem on mine today. I couldn't find instructions so I made some on snapguide. Search wcufi-tower-fan/
May 31, 2009 | Windchaser WCUFI WindColumnUltra Tower Fan
Model number not listed
That is a good question. My Model FTR184 Windchaser fan is not working either (has standby light on, and doesn't run, even when temperature setpoint is reduced to less than room temperature (in the PS - personal settings - mode), and more frustratingly, even in the FAN mode, where there is not supposed to be a Standby mode. That darned red Standby LED light just stays on no matter what mode I have fan in (though it does go off when I operate the Power on/off switch to turn everything off. So, I agree with Lease. Why isn't our fan model listed? And, of course, what is wrong with mine.
Sep 02, 2006 | Windchaser FTR163 SensorFan Stand...
Windchaser FTR163 SensorFan Stand (Pedestal) Logo
1,015 people viewed this question
Top Windchaser Dryers Experts
Ian Summerfield
Ian Summerfield
john h
Vernon Taylor
Are you a Windchaser Dryer Expert? Answer questions, earn points and help others
