A
Anonymous Posted on Jun 26, 2014
What is the Square root of 7750 is ?to the nearest whole number
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Office Equip... Master 102,366 Answers
  • Posted on Jun 27, 2014
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442950
Points
622693
The square root of 7750 is about 88.
1 Related Answer
Anonymous
  • Posted on Feb 18, 2010
SOURCE: On my TI-30xs Texas Instruments, I cant figure out
Use the toggle button above the enter key. It looks like 2 arrows
What is the closest whole number for the square root of 148?
Twelve (12).
12 squared is 144, 13 squared is 169. 148 is closer to 144 than to 169, and the square root of 148 is about 12.166.
How do I do math problems estimate roots
To do them it REALLY helps if you remember Perfect Squares.it will make you quicker at doing these problems.
From this page http://www.gmathacks.com/mental-math/estimating-square-roots.html
I have copied a section below.
For these problems.....
you don't need the exact answer! An approximation is good enough
. Memorize Squares
For all sorts of reasons, you should memorize perfect squares at least up to 12^2 = 144. It helps to know additional round numbers, such as 15^2 = 225 and 25^2 = 625.
Once squares are burned into your memory, estimating square roots is easy. Let's go back to the square root of 39. The nearest perfect squares are 36 and 49, which are squares of 6 and 7, respectively. Thus, the square root of 39 is somewhere between 6 and 7. Since 39 is closer to 36 than to 49, the square root of 39 is closer to 6 than 7.
Sure enough, the square root of 39 is about 6.24. You will never see a problem on the GMAT where you need to know that the square root of 39 is 6.24. But you may well need to know that the square root of 39 is a little bigger than 6.
We all had to learn these at one time.
Give it a go friend :) You won't regret it.later on in life.
2answers
How to calculate the square root
The square root is the second function of the "3" key. To calculate the square root of 3, press 3 2ndF 3 =
Convert square root to decimal TI-30XA
Press 2nd then F--D key(its means left arrow key or left key from zero)
1helpful
How can you use the square root key to find the square root number?
Press 2nd [square-root], enter the number, press ) =
For example, to calculate the square root of 5, press 2nd [square-root] 5 ) =
3helpful
I cant figure out how to get the square root of a negative number
The square root of a negative number is an imaginary number, and the TI-30XA does not deal with imaginary numbers.
However, the square root of -x is equal to i times the square root of x. So, to calculate the square root of -4, for example, press 4 square_root = and read 2. Thus the square root of -4 is 2i.
Square root
It may be that you have somehow changed to a 'mode' that only shows integer values.
Try pressing the green button, then 5, then 9. Then try the calculation again.
If this fails, you can use Google as a calculator - search Google for sqrt(0.4053) and see what happens.. :-)
k24674
ADMIN Andrew
ADMIN Andrew
