Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Replaced bulb in Mitsubishi WD-52525 and it still does not work
  • 64 Answers
What does not work? Does the green light flash or light at all? Can you "manually" turn on the tv? If the light is RED...the replacement was either installed incorrectly (or is not plugged in correctly to the contacts at the rear) or is the wrong bulb. Be sure the door to the front of the bulb in on as there is a micro-switch at the lower right that MUST be engaged.
Posted on Aug 01, 2009
Wd-52525 flashing green light reset does ot fix. have to unplug for a few seconds to fix. Is this a conputer probem inthe TV?
Ur DM power supply board have problems.U know how to solders?Capacitors bulb up or pop open.Replaced this capacitors will fix ur Flashing power.Tries website Tv repair World.com to buy these capacitors to replaced.
Apr 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My mitsubushi wd 52525 we replaced bulb but can't turn timer light keeps flashing what do i do
This is due to failing capacitors in the power supply. Many people have fixed them self repair but it takes some skill. If you cannot do this yourself, contact Mitsubishi. They will help with the repair under an extended warranty. You will have to pay labor.
Feb 01, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green Blinking Light WD-52525
Is it possible your having poor air movement around the set. If lamp is frequently blowing it sounds like over heating. Sorry your having troubles. That tv offers a fine picture.
Jul 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
You have a bad DM Board. You need to replace it. Changing the capacitors will not cure the problem. Completely replace the entire board
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen on WD-52525
Hi, Standby i'll sent you how.for a while
Apr 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Wd-52525
This chassis has bad capacitors on the PWB,FMt, DM and the other boards that need to be replaced. They are all jamicon capacitors 1000uf and larger there are roughly 10 in the set that need to be replaced. Let me know if you need further instructions on this model.
Apr 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-52525 no picture or sound
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
