Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster not responding to any remote. Learn
Liftmaster not responding to any remote. Learn light is blinking in a 5 time sequence. I get the click but the motor does not react and the light does not function. do i need a new unit?
    President:
  • 3,197 Answers
If the door is stuck in the open position it probably because the trolley is jammed against the bolt just in front of the motor unit. Remove the bolt and run the opener until the door is closed. On the side of the unit you will find an adjustment for the 'up limit'. Turn this about 3 turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Post back if this isn't your problem.
Posted on Jun 27, 2009
The unit is displaying a sequence of 5 flashes with the amber light. When I try to open the door, it will only go forward and backward aprrox. 1 ft. Any suggestions on what I should do?
Craftsmsman 1/2 HP opener indicator light blinks five times ...
? 0:29
https://www.youtube.com/watch?v=AvXJd-tYCJ0
Apr 28, 2012 - Uploaded by bship452
Then showing the amber indicator light blinking 5 five times, stops ... push remote to operate opener, you hear a clicking sound from the unit. ... Show more .... blink 5 times (looks almost alike) If I forced the garage door closed, ...Missing: sequence
Sears Garage door opener problem - Home Forums
ths.gardenweb.com > Home Forums > Garages/Workshops
Jun 27, 2006 - Now, I cannot get the light in the sensor at the door to come on. ... the green LED went OUT about 1/2 way up the door opening sequence. .... other is working (I don't recall if it's green or amber, but know that it is lit.) ... Their is also a green LEDflashing 2 times every 5 seconds or so at control center of unit.
Craftsman Garage Door Opener Problem - Home Forums
Jan 05, 2016 | Building Materials
Chamberlain Liftmaster GDO just clicks, no lights no open/close
Pull the logic board and check it for burnt or missing traces on the printed circuit. Thunderstorms love logic boards.
Apr 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster mod 1245R (1999) has indicator light blinks 5 times. Door will not operate from hardwire button. Tried unplugging unit to reset but same 5 blink sequence returned. Held button in to reset but no...
The trolley is most likely jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. Now locate the 'up limit' control on the side of the motor unit. Turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Dec 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster mod 1245R (1999) has indicator lightLiftmaster mod 1245R (1999) has indicator light blinks 5 times. Door will not operate from hardwire button. Tried unplugging unit to reset but same 5 blink...
The LED flashing 5 times is the code for "RPM sensor or motor overload". Usually if it is the RPM sensor - which is a small printed circuit board just in front of the motor - it will run a few inches and then reverse. I doubt very much it is the motor. I would pull the logic board and check for loose or missing traces on the printed circuit. Especially if you have had any electrical storms or power surges.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage opener not responding with remotes, keyless pad, or wall console. Can hear it click but nothing happens. Green light in opener blinks 5 times. When i reset the green light stays on until i try to...
UNPLUG UNIT TO RESET.
IF IT STILL FLASHES 5 TIMES AND MOVES 6-8 INCHES REPLACE RPM SENSOR.
IF IT STILL FLASHES 5 TIMES AND DOESN'T MOVE REPLACE LOGIC BOARD.
Apr 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener Clicks only and LED blinking 5 times
Just fixed this problem tonight. Had the 5 blink/flash thing. Opened it up and saw that the motor wasn't spinning so it wasn't a bad rpm sensor. Jumped the red to black and then the blue to black to verify motor worked. At that point assumed it was the logic board not telling the motor to start, but I could hear the click of the relay. Pulled the logic board out and noticed a solder joint that had failed directly behind one of the relays. Resoldered that joint and the garage door opener worked again like a dream. Hope that helps someone else.
Feb 28, 2009 | Building Materials
Light flashing after opening
look in your book it will tell you the problem count the numer of blinks
Jan 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftman garge door opener changing code on key pad
having all the remotes you want programed with you, find learn button on back of opener. hold button until little light goes out- no remote will work now, with each remote Press learn button once,Press big button on remote-light bulb on opener will blink on/off if bulb is working-do this each hand held-keyless is same way, put you 4 #'s in HOLD enter button-light bulb blinks on/off you have 15 sec. for each time you hit the learn button. also best to start off with new 9 volt battery before you start programing
Aug 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Trouble changing passwordon model 940CB wireless keyless entry
easyer then that , you die! Open your garage door, take out the step ladder, a chair or get up on *********** in law's back, (here's your chance to be on her back for a change) press the read button of your unit (motor) a led should light up and on the key pad, key in the new 4 digits code and press enter, the light of the unit should blink javascript:; Post Solution
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
517 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
