Question about Kenmore 24032\24036 Top Load Washer
Kenmore series 90 started to washe but did not rinse nor spin. coupler is not broken. what to check for?
  • 5,911 Answers
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Posted on Jul 07, 2009
The console is bookmarked by two plastic pieces. Take those of by sliding them to the side firmly. Unscrew those screws and lift the console so it hangs over upside down, Unplug the plug and pull the clips out by setting a screwdriver down into the front of the clip and push the screwdriver away to spread the clip open until they both pop out. Pull entire metal casement away. If it's the motor coupler you'll see black rubber crumbs on the floor. goto the repair clinic to get a new set. They're cheap.
I have a kenmore 90 series washer that won't spin. It makes a grinding type noise at that point in the cycle. I followed the trouble shooting guide and checked the motor/gearbox coupler. The coupler looks...
If the coupling is OK then the problem is most likely to be further up the drive-line, which means the gearbox has probably failed. .........Nomess
May 16, 2010 | Washing Machines
Kenmore 90 does not spin (sounds like working & coupler is good)
If the coupler is ok then the next thing to check is the brake/ basket drive cam driver, the ear breaks off on em and won't release the brake. You must remove the agitator and drop the tranny to check itffbcc2d.jpg
Nothing is difficult about repairing the washer. I have repair photos HERE
Mar 13, 2010 | Washing Machines
My kenmore 90 series filled with water and went it got to the rinse cycle it quit working and just started making a grindling sound. help please
sounds like the motor coupler broke. it's a plastic piece near the motor and very easy to replace.
here'e a video you can watch to make it easier:
http://www.youtube.com/watch?v=nM4DW2bq7o0
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Kenmore series 90 washer won't go into Spin
This is probably a bad drive coupler between the motor and the gearcase assembly.
Go here for:
Kenmore Washing Machine Parts
RepairClinic.com
appliance parts, help & more
Sep 20, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
Kenmore 90 series will drain but not spin
You definitely have a broken motor coupling. This is the piece that connects the motor to the trasmission. The pump is connected directly to the motor on the other side opposite of the coupler. When they break, the water will drain but the washer will not spin.
Here is a repair manual that will help you replace the motor coupler.
If you have anymore questions please ask. This is an inexpensive repair and something you can do yourself. Just refer to the coupler in the manual and you won't have any issues.
Thanks
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
My kenmore 90 series model # 110,c28922790 will not spin
Your motor coupler is broken, its # 13 on the diagram, part # is 285753, you can live chat with me and Ill describe how to install it, hope this helps, dave www.washermd.com
Dec 17, 2008 | Kenmore 24032\24036 Top Load Washer
Squeaking/grinding/rattle noise during wash and spin
That sounds like a clutch problem - probably just worn and need replacement. Will definitely need to pull to find exact fault.
Regards
Nov 16, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
106 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
