Question about Sony STR-DE445 Receiver
I have a sony str de445 and it overheated one nite and stoped working. when i click the power button it clicks as if it turn on but no display or sound or anything, could you help please
    Problem Solver:
  • 5 Answers
You might have burned up some internal parts, it is very important that you keep your unit well ventalated so that it has less of a chance at overheating, check for any internal fuses that might have blown.
Posted on Dec 12, 2009
Not getting power, but makes a clicking sound when power botton is pressed
One of two things.
1) open power transformer (easy but not cheap)
2) short circuit (output transistors) that opened fuse. (more difficult but less expensive)
Jul 17, 2010 | Sony STR-DE445 Receiver
The reciver is stuck in demo mode. Can`t get it out of demo mode.
The demonstration will activate the first time you turn on
the power. When the demonstration starts, the following
message appears in the display:
“NOW DEMONSTRATION MODE IF YOU FINISH DEMONSTRATION PLEASE PRESS POWER KEY WHILE THIS MESSAGE APPEARS IN THE DISPLAY THANK YOU”
To cancel the demonstration
Press the Power 1/0 button to turn the receiver off while the above message is being displayed. The next time you turn the receiver on, the demonstration will not appear.
It's in the manual - page 3.
Jun 10, 2010 | Sony STR-DE445 Receiver
Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
Feb 13, 2010 | Sony STR-DE445 Receiver
Sony str-de845 powers on, relay clicks sound works for a few minutes then relay clicks again and sound stops. display stays on.
Hi there, can anyone help me? i cant seem to get my aiwa-d58 to get out of eco mode. no power, red light is on and every time i press the power button; the eco light clicks off and i no power supply to the whole unit. please help!
Jan 22, 2010 | Sony STR-DE845 Receiver
Trying to use a passive subwoofer with STR-DE445
The output of the Sony is "signal only" not power. Being "passive" like your sub. What you need is a sub amp, and they are not cheap, 400-600 on average "min". Unless you have a Velodyne 15 or 18, just get an amplified sub, they start around 150 new. Hope this helps
Mar 27, 2009 | Sony STR-DE445 Receiver
Speakers pop and rear speakers cut out of surround sound
your problem is a bad solder connection of the relay linked to the lautspeaker sockets. I had the same problem and googled for the solution. Since I resoldered the pins everything is fine. That problem is well known and happens to a lot of Sony receivers.
I can send you a link with a detailed how-to-do solution with pictures, however it's written in german language. But you can use some online translators.
Here is the link: http://www.bmw-syndikat.de/bmwsyndikatforum/topic.asp?TOPIC_ID=28280&FORUM_ID=20&CAT_ID=9&Forum_Title=Geplaudere&Topic_Title=Problem+Sony+STR-DE445
Ralf (from Germany)
Jan 07, 2009 | Sony STR-DE445 Receiver
No sound in DVD mode
when i turn on sony receiver it will not play it just says protect on the screan
Dec 21, 2008 | Sony STR-DE445 Receiver
Receiver str de 445
Hi - You can download the manual from the link underlined in blue below:
STR-DE445
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Sony STR-DE445 Receiver
STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
Sony STR-DE445 protect displayed
It sounds like a bad solder connection. It just needs to be soldered up, if you take it into a shop just tell them it doesn't need any new parts, it just needs to be soldered up.
Or, if you can solder it yourself, or know someone that can, that would be much easier.
Aug 04, 2008 | Sony STR-DE445 Receiver
Sony STR-DE445 Receiver Logo
273 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
