Question about HP LaserJet 3050 All-In-One Printer
HP 3050 Firmware
I downloaded a firmware upgrade for HP 3050, installed it and now the printer is unresponsive. The menu button (or any other controls) on the printer will not respond. My computer can not print even a test page. What should I do?
  • 57 Answers
SOURCE: HP PSC 2210 All-In-One InkJet
I undertand that you are receiving a blank page when printing from computer.
Please follow the below given instructions to get the issue resolved which is caused due to DEP feature of Operating sytem.
Disable the Data Execution Prevention in Windows XP and check by following the below steps:
1. Click on Start
2.Control Panel->System->Advanced->Performance->Settings->Data Execution Prevention
It needs to be set to "Turn on for essential windows programs only", which is the default.
If you set it to "Turn on for all programs except those I specify", then the all-in-one driver stops working and you get blank pages.
1) Right-click on My Computer, and select Properties.
2) Click on the Advanced tab.
3) Under Performance, click Settings.
4) Click the Data Execution Prevention tab.
5) Select the Turn on DEP for all programs and services except those I select: option.
6) Click Add....
7) Browse to C:\WINDOWS\system32\spool\drivers\w32x86\3\hpzeng05.exe
Or
C:\WINDOWS\system32\spool\drivers\w32x86\3\hpzeng07.exe
and click Open.
8) Click Apply.
9) Click OK, and OK again.
Then restart the computer so as the chages to be effective
Posted on Feb 08, 2008
SOURCE: Printer not responding. recently upgraded the firmware version
check the usb cable connnections
Posted on Feb 16, 2009
SOURCE: HP 7350 printing goes through the motions but nothing
I had the same problem and couldn't figure it out until I found this on the web - I changed the DEP setting and now I can print just fine. Hope this helps you too!!
Julia
Source:
http://www.tech−archive.net/Archive/WinXP/microsoft.public.windowsxp.print_fax/2006−06/msg00081.html
· From: Shawn D <ShawnD@xxxxxxxxxxxxxxxxxxxxxxxxx>
· Date: Sat, 10 Jun 2006 07:40:01 −0700
I just figured out my issue. It had to do with DEP − Data Execution
Prevention. I had remembered that I was fooling around with this a couple
weeks ago and had changed it to "Turn on DEP for all programs and services
except those I select" in which I had Windows Explorer checked. I just got
done selecting the original which states "Turn on DEP for essential Windows
programs and services only", rebooted, and now I can print again to my hp
7350 printer.
The DEP can be found under control panel−>system−>Advanced Tab−>Performance
Settings−>Data Execution Prevention Tab
Hope this helps.
Posted on Mar 06, 2009
SOURCE: HP PSC 1610 All-in-One not printing anything including test page
try this.. i got the same problem before.. and the main problem is the NO MECH MODE.. try pressing the setup button then take the plug out of your printer.. (still pressing the setup button) and put the plug back.. and it will remove the no mech mode.. then you could print like before.. i hope this helps
Posted on Jul 20, 2009
  • 3 Answers
SOURCE: HP Color Laserjet 2600n Color Alignment
I own a HP 2600n and I had the same problem the way I fixed it was hold both arrow buttons in the turned off the power for 10 seconds while holding the buttons in then turned it back on then released after 3seconds the reset my defaults this cured my problems
Posted on Nov 12, 2009
HP LaserJet 2840 quit working when we were installing firmware update and power to building went off for a few seconds.
firmware corruption issue you will need to remove that printer from computer screen then reinstall it
then do firmware installation pre upgrade to stabilize(use cd or download of older version of firmware
once that's done then try the update again which won't work if old firmware is corrupted
May 17, 2012 | HP LaserJet 2840 Printer
Download file now send rfu upgrade on usb dev port
Determine the current firmware version 1. Press Menu . 2. Press the down arrow to highlight INFORMATION, and then press OK. 3. Press the down arrow to highlight PRINT CONFIGURATION, and then press OK to print. The firmware datecode is listed on the Configuration page in the section called Device Information. The firmware datecode has this format: YYYYMMDD XX.***.X. The first string of numbers is the date, where YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20061125 represents November 25, 2006. Download new firmware from the HP Web site To find the most recent firmware upgrade for the product, go to www.hp.com/go/ ljp4010series_software or www.hp.com/go/ljp4510series_software. This page provides instructions for downloading the new firmware version.
Aug 05, 2011 | HP LaserJet P4015N Printer
My printer (P3005 PCL6) is showing an error 49.4C2D. However, it is printer may four pages that is after I switch it on and off and eventually it stops. Please help me
Hi
HP describes these as 49.XXXX errors (without the suffix numbers after the . (dot)). The general description is that a critical firmware error has occurred, but it's usually not firmware, especially if the printer has been fine until recently.
Usually it's corruption in the print stream for a particular print job, so it could be the program (does this happen with print jobs from a particular application or from all applications; have you installed new software or upgraded it recently for the application that causes the error if it's always the same application?), the driver (have you recently upgraded it?), data corruption in the connection to the printer (bad network or USB cable, etc.), or maybe the firmware.
If they're random, and you can clear them and bring the printer back to ready by clearing the print job out of the spooler, turning off the printer, then turning it on again, it's most likely corrupt data in a print job introduced by one or more of the factors above. If they're infrequent and not too much of a bother, you can just do that.
More information - here's an HP support document on troubleshooting 49.XXXX errors:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=83436&prodTypeId=18972&prodSeriesI
d=83436&objectID=c01558499
Sometimes but rarely, they can be corrected with a firmware upgrade IF your model's firmware is flashable, and IF the problem is in the list of fixes.
Approach upgrading firmware cautiously since a firmware upgrade that doesn't install correctly can render the printer inoperable until you replace the firmware dimm with a new one.
To check for an available upgrade, go to hp.com.
Click Support & Drivers.
Select "Download drivers and software (and firmware)".
In the text box, type your model, ie: laserjet 2420d in your case.
Click the arrow button to the right of the text box.
At the next screen, pick your specific model if it's not already selected.
At the next screen, If a link named Cross operating system (BIOS, Firmware, Diagnostics, etc.) is there, the firmware is flashable. Click it.
If it's not, you would have to buy a new firmware dimm from HP to upgrade the firmware.
Important - At the next screen, do not click on the Download button. Instead, click the named link for the firmware for your operating system.
At the next screen, select the Read me tab. That contains all the information from all tabs.
Important - The cautious part: Look for your specific error in the Fixes list in the Readme tab information. If it's not there, I'd recommend not installing new firmware.
You can also contact HP directly for help. Just click your country here:
http://welcome.hp.com/country/us/en/wwcontact_us.html
I understand they now charge for phone support, but that chat and email support are still free.
if my solution is helpful you then give me thumb
Jun 24, 2011 | HP LaserJet P3005 Printer
I got and error message on my printer hp p2055dn 49 err 6400444 turn off then turn on
You probably are printing with a newer version of adobe and have not upgraded the firmware on the printer. Go here and download the firmware update utility, first option for upgrades on the page. Once downloaded run this utility and it will ensure that your firmware is up to date. If you cannot get the printer to come to ready, you will need to clear any print jobs that are in the queue waiting to print first.
Apr 07, 2011 | HP P2055DN LaserJet Monochrome Printer
How to solve service error 49.00 in hp laserjet 2430dtn printer
49.XXXXX ERROR
A critical firmware error has occurred.
1. Press Cancel Job to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on again.
3. Go to http: www.hp.com/support/lj2410, www.hp.com/support/lj2420, or
www.hp.com/support/lj2430. Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the
one installed on the printer and the printer can receive a firmware update,
download the newer firmware upgrade. Not all printer models can
receive firmware upgrades.
4. Try printing a job from a different software program. If the job prints, go
back to the first program and try printing a different file. If the message
appears only with a certain software program or print job, contact the
software vendor for assistance.
1. After performing the actions listed in the preceding item, if the message
persists when using different software programs and attempting specific print
jobs, disconnect all cables that connect the printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs and thirdparty solutions from the printer.
4. Remove all of the EIO devices from the printer.
5. Turn the printer on.
6. If the error message disappears, reinstall each DIMM, Compact Flash card, and EIO device one at a time, making sure to turn the printer off and then on again (booting to the Ready
prompt) as you install each device. To replace a DIMM, see Appendix D - Printer memory and expansion in the LaserJet 2400 Series User Guide.
7. Replace the DIMM or EIO device that caused the error message.
8. Remember to reconnect all of the cables that connect the printer to the
network or computer.
9. If the error message persists, reinstall the firmware with the latest possible firmware upgrade. Go to http:www.hp.com/support/lj2410, www.hp.com/support/lj2420, or www.hp.com/support/lj2430. Click Download Drivers and Software.
Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the one installed on the printer and the printer can receive a firmware update,
download the newer firmware upgrade. Not all printer models can receive firmware upgrades.
10. Replace the formatter
Feb 28, 2011 | HP LaserJet 2430dtn Printer
Wrong firmware installed in HP LJ 3050
I am very sorry to have to be the bear of bad news. Usually doing a failed firmware update (or wrong firmware version) you have to return to factory or have a local computer printer shop that deals in HP printers repair this firmware mixup. There is sometimes a firmware recovery mode that can help however You would have to contact HP and ask them how to get into firmware recovery mode.
Sorry hope this helps answer your quesiton.
Steven.
Apr 22, 2010 | Office Equipment & Supplies
Nextar ma852-801 mp3 freezing...reset?
Hi.
Welcome To Fixya Community.
Solution 1:
  • Try to Turn it ON/OFF(Reset).
If that isn't Working try This:
Solution 2:
  • You are going to upgrade the Firmware of your Mp3 Player in order to perform that follow these Steps:
  • Installation of the Upgrade Tool:
  1. Download the Upgrade Tool application (the download link is in the bottom of this Solution) to your computer.Double click the application.Follow the instructions shown on the screen to complete the installation.Firmware Upgrade:Note: All the existing files in the player will be erased while upgrading,please make a copy of your files before doing this.Turn on MA852-801 player. Press and hold the MENU button todisplay the main menu. Select “Settings” → “System” →“Upgrade” and press the MENU button to confirm. Select “Yes”and then connect the device to a computer via USB interface once you see the following window:
2. Select ”Program files” 􀃆 ”Firmware Update” from the Start
menu or double click the “Firmware Update” icon on the
desktop. You will see the following window shown on the
screen:
6fc021c.jpg***************************************************************************************
3. Click Open button, and specify the upgrading firmware with
the extension “ .rfw ” (Please download the firmware from
Nextar website named MA852-801 – updated firmware.rfw).
Click Update button to start upgrading.
Note: This process may take about 2 minutes depending on the
computer system you use. Please don’t disconnect while upgrading,
it may cause serious damage to the player.
4. Once it shows "Firmware update successful"wording in
“Update Info” window, then click Exit button to finish
upgrading.
*************************************************************************************(5) 5. Safely remove the player from the PC.
6. Turn on the player. Please wait about 20 seconds for the
player to automatically initialize settings.
Downloads:
Upgrade Tool.
Firmware File.
Additional Help:
Nextar Ma852-801 Mp3 Player Manual Guide.
please don't hesitate asking me if you need any Further Info.
Thank You For Using Fixya.
Good Luck.
Nov 04, 2009 | Audio Players & Recorders
Hp 2420 service code 49 2F90 what does it mean?
support/lj2420, or
Software
. Check for the
upgrades.
Failing that replace the formatter
Aug 13, 2008 | Office Equipment & Supplies
49.4c02 service error coming in hp laser jet 2420dn printer
This is a firmware error, you can try turning the printer on and off a few times, reseating any memory and the formatter board. If these steps don't work Go to http: www.hp.com/
support/lj2420, or
Software
. Check for the
upgrades.
If still no joy replace the formatter (this is the normal coarse of action)
Aug 13, 2008 | HP LaserJet 2420dn Printer
HP LaserJet 3050 All-In-One Printer Logo
252 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
