Question about Kyocera FS-3830N Laser Printer
TRYING TO CHANGE THE DRUM AND NOT SURE HOW TO GET IT OUT.
    President:
  • 3,085 Answers
Open the top door
remove the toner cartridge
unplug the DV unit plug on left side
move spring loaded gray lever to the rear and hold
grasp the vertical part of the DV unit , lift up and out
open left door
remove the waste bottle
push small gray button on drum and pull drum out
remove tape on new drum carefully
reverse procedure to install.
Posted on Jun 27, 2009
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
I've removed the back break drum to change the shoes, but the drum will not go back on. any tips?
Make sure the adjuster is backed off enough to allow the drum to slide over the shoes.
Sep 22, 2012 | 2007 Dodge Caliber 2.4
I am trying to find the drum, I have a line on my copies and would like to get rid of it.
The line is only in your copies?????
If so you problably have the mirror scanner durty.
Make a print and see if the line are stil there. If so, open the front door and next to the toner unit you will see the fotoconductor unit. inside you have the drum. I advise you to change not only the drum but also the blade.
Just make sure the line apaned also copy and print. If so you are right, the drum is faulty.
Good luke
Feb 21, 2011 | Ricoh Aficio 2022 Black and White Copier
Trying to change the heating element
take front cover off first, then top cover, then remove dryer drum belt and drum and replace element
Sep 23, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Needed to change drum...so did that. Just changed
I am not sure what kind of printer this is, but see if there is a reset menu for the drum. also the manufacturer website might have some info on how to reset the drum counter.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Jul 31, 2009 | Dell 1720dn Laser Printer
Brother MCF-7340 first time toner replacement
If this model comes with the drum separately of the cartridge, only replace the cartridge. There's no need to change it every time. until prints start to get lines or dots. Don't expose the drum to light too much.
Jul 30, 2009 | Brother MFC-7340 All-In-One Laser Printer
Need to change cleaner blade on drum
Remove drum unit, remove Drum, remove blade (2 screws)
** coat the new blade with some toner, or it will flip, when the drum start to turn, due to the friction. And always manually rotate it yourself prior to re-installation to make sure it is ok
Apr 28, 2009 | Canon C330D Copier
Drum life low replace soon Error Message
I already answered this at some other place here - but just to make sure the word gets out there:
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner assembly - and you can rotate it counterclockwise all the way back. This should reset the drum counter - worked for me!
I hope it also does the trick for you ;-)
Apr 03, 2009 | Panasonic KX-MB781 All-In-One Laser...
Imagerunner 1310 drum change
To change the drum you have to slide the plattened cover to the left,like you do when removing a paper jam,open the top cover,you will see a handle that you pull to remove the defeloping and drum unit,remove the drum and def unit.
The drum is attached by two clips on top of def unit,unlock the drum from the def by releasing that clips,slide te drum protecktion plate to the rear and remove the drum.insert the new drum by reversing this steps.
If your image of your copies is not bad you can remove the waste toner in the drum unit before replacing it.On top of the drum there are two plugs open them and remove the waste toner,make sure you remove all of the waste toner.Then that message will go away.
Jan 31, 2009 | Canon imageRUNNER C3200 Copier
Rear Brake drums?
Start loosening the adjusters, blow out the dust with compressed air, do not breathe the dust as it is toxic.If it does not come out you will need to hammer carefully around the rim. If it still does not come out use a ball ping hammer, and hit the center of the drum being extremely careful not to hit the studs or you will damage it.
An alternative way to do this is hitting the drum in the center avoiding the studs and making sure you are hitting the drum and not the axle. Usually you hit it a couple of times with a hammer and the drum comes off. If you do not do it the right way you may damage brakes, studs and axle.
Aug 24, 2008 | 2005 Chevrolet Colorado
Kyocera FS-3830N Laser Printer Logo
160 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
