Question about Compaq Presario Notebook
On recently installed new keyboard the first 2 rows of keys only the 5,6, T & Y keys work properly. Can you provide any assistance?
Upper number not working only 5 and 6 how to fix this?? plzz need help
Do you mean the symbols don't work - % and ^ above 5 & 6? or is it that only 5 & 6 work and rest do not work in the upper row? Try to plug another keyboard to isolate the problem to be a keyboard problem. If with the second keyboard also, you face the same issue, it is driver's of your keyboard which you can try updating. Also check if your keyboard software is mapped properly to the keyboard type you are using.
Jan 08, 2014 | Dell SK-8115 Keyboard
I have a studio 1749 my problem started after i removed the keyboard to clean it because of the dusty enviroment i work in. After putting the board back in i noticed the entire 2 bottom rows of keys didnt...
it's more likely you haven't put the ribbon cable back properly. try removing the keyboard again and reinsert the ribbon cable carefully - remeber there is a bable grip that needs to opened to remove the cable and closed again after insertion to maintain contact
Apr 11, 2011 | Dell Studio 17 (1749) Laptop black -...
Gateway MX6124 laptop: some keys on the right side of the keyboard display numbers instead of letters. Keys involved and actual display are: Row Starting with q: u=4, i=5, o=6, p=*, Row Starting with a:...
Your computer is in keypad mode. To check, turn off your Num Lock. On my system that disables the embedded keypad. To fix, go into setup (usually F1, F2 or delete when booting). Somewhere you should find a setting for using the embedded keypad. Mine has two options, Fn Key Only and By Num Lock. Yours may be different. One activates the embedded keypad, which you are seeing. Try the other setting.
Apr 25, 2010 | Gateway MX6124 Notebook
THE KEYS ARE ALL SWITCH TO DIFFERENT CHARATERS WHEN I PRESS M GIVES ME 0
ok here from left to right top row esc f1 f2 f3 f4 f5 f6 f7 f8 f9 f10 f11 f12 prtscrn scrolllock pause second row ~ 1 2 3 4 5 6 7 8 9 0 - = bkspc insert home page up num lock / * - third row tab q w e r t y u i o p [ ] \ del end pgdn 789+ fourth row caps lock a s d f g h j k l ; ' enter 4 5 6 fifth row shift z x c v b n m , . / shift up 1 2 3 enter bottom row ctrl windows key alt spacebar alt windows right click ctrl 0. hope that helped
Oct 11, 2009 | Compaq Keyboard
I need 2 keys for my p205-6287
you can order a replacement keyboard from ebay and replace the whole thing. its a couple of screws and when pulling apart the laptop you must be careful of the clips. Also they probably sell them by the key on there.
Jul 24, 2009 | Toshiba Satellite P205-S6287 Notebook PC
S510 Keyboard Problem, Keys Dont Work, Everything Else Works,Ect-Mute
I had the same the problem. The cause was a corrupted encryption code. That is why only worked the keys that don't require encryption.
1) Install the Logitech software and restart.
2) The software will tell you to press CTRL-ALT-F12. This procedure resets the keyboard encryption and tells you to enter a new code.
3) If you already had the software installed simply press CTRL-ALT-F12 and follow the above procedure.
Mar 15, 2008 | Logitech Cordless Desktop S 510
Compaq Presario Notebook Logo
16 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
