Question about Garden
A 312A Wheel horse. It stopped running the last
A 312A Wheel horse. It stopped running the last time I used it. It was running at med to low trottle and it stalled. Now it won't start. Has fuel
    Sergeant:
    Champion:
  • 351 Answers
Clean carb also check points
Posted on Oct 08, 2010
  • 61 Answers
Ck for 12 volts to coil
Posted on Sep 06, 2009
Toyostove Laser 73 heater will not run, and the low/med/hi lights flash on and off?
Remove front grille by taking out two screws at lower right and left front sides of stove. slightly pull botom front of grille toward you and lift up and off. Look for two red wires going into burner chamber, the wires will be incased in a gray plastic sheath as they enter chamber. Push on buton like you are trying to start the heater. While it is going through start up process hold the gray plastic sheath with two fingers and see if the sheath does not get warm in a short period of time the igniter is bad and will need to be replaced. This can be cause by water getting into the burner chamber and causing the igniter to crack.
Jan 05, 2013 | Rinnai Toyostove Direct Vent Heater:...
How it works invicta clock mechanism ?
Your watch is battery powered or a 'quartz' watch. It is commonly refered to as a 'chronograph'. That is another word for stop watch.As well as telling time and the date, your watch can time how long an event lasts. For example, a horse race. You start the chronograph or stop watch when the horse starts and stop it when it crosses the finish line. When the next horse starts you need set it back to zero to time the next race.Operation is simple. The upper push button starts and stops the chronograph. Try it. Now with the chronograph stopped, push the bottom button. The hand return to the 12 o'clock position or the 'zero' position. Also notice the small dials on the dial or face of the watch. They record minutes and other increments of time. The large hand going around when you push the upper button is recording seconds. Hope this helps, Michael
Oct 09, 2012 | Invicta Lupah Collection Chronograph #9813...
Intertherm a/c hardly blows on low fan setting
are you saying the outdoor unit does run, then shuts off?
if not, there may be fuses in the disconnect
if so, it may be going out on low pressure, possibly high pressure....clean all coils, filter, blower wheel, inspect coil if possible
Jul 26, 2012 | Dometic Rooftop RV Air Conditioner
Troy-bilt horse engiine runs good , tines work,
The wheel shaft on a Horse tiller is one piece so if the shaft turns on one side it will turn on the other. make sure the pin that holds the wheel on is not missing that would let it spin on the shaft.
That's the only thing I can think of that would cause that problem. Hope that helps.
Frank
Aug 29, 2010 | Troy-Bilt Garden
Low does not work, medium and high do
You probably cant fix it, this sounds like a multispeed blower with hi/medium/lo settings. You
can either replace the motor or connect one of the
working speeds to low/med or low/hi. or bump med to low and high to medium.
Jan 12, 2010 | Desa International Blower Glow Warm Wall...
1975 75 horse johnson stinger wont idle in gear or run in gear
sounds like the reverse sensor switch is stuck in lock mode
check the switch
Aug 03, 2009 | Boating
I have Nextway nmp 312a but i don,t have drivers for him.
i need a driver for nextway 312a . i want to give it my doughter. please help me soon greetings Stephan
May 10, 2009 | Nextway NMP-312A (128 MB) MP3 Player
Have weatherking furnace, Pilot lites but no blower
I am thinking the fan is bad if you can disconnect the fan motor leads and ohm them out. White is common Red is low speed Black is high speed. You might have other colors like blue which would be med speed and maybe orange witch would be med low. There is a small run capacitor on the fan so replace both fan and capacitor at same time. After you ohm out the motor of course. You should have resistance on all leads. Use white as the main one and check each speed. Replacing the motor isn't too tuff little hard getting it out of squirrel cage
Dec 20, 2008 | Heating & Cooling
Garden Logo
272 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
