Dometic RM2852 Refrigerator
Problem for Dometic RM2852 Refrigerator
Dometic RM2862 Can you reset the thermo fuse?
By jdsbose on Jun 27, 2009
dometic RM2862 Can you reset the thermo fuse? Current going to it but nothing going out and wouldn't this cause the unit not to work at all?
Solution #1
posted on Jun 27, 2009
Not Rated)
ronaldo_ross
Rank: Wiz
Rating: 84%, 300 votes
It probablby has a timer in it. You can reset the timer by turning it clockwise, and the compressor would come on again. It is usualy located under the concoles where the setting button is located. Look for a small hole under that console. If a thermal breaker is making the compressor cut off, it is usually located on the compressor where all the wiring are going in, along with the starting capacitor. Usually if the compressor is overheating and making the thermal breaker go off, there is a problem with the compressor, or it is low on refrigerant. A low refrigerant will make a compressor overheat. Furthermore if the compressor has been being overload by low refrigerant, it will be damaged sooner or later, by overheating the elecmotor inside and causing a short. If resetting the timer don't work and it is indeed the thermal breaker, unplug the machine and get it service, which I hope the compressor is still okay.
Was this helpful?
Yes
No
Popular Solutions for Dometic RM2852 Refrigerator
Questions and Unsolved Problems for Dometic RM2852 Refrigerator
Do you recommend Dometic RM2852 Refrigerator?
Answer
Answer
I have a rm2862 dom. it has 12v and 110v power to the ref. the silver case in the back of the ref is... (More)
Answer
the cooling fins in my unit are freezing up. drinks are frozen eggs, are frozen. help me out, can... (More)
Answer
Dometic RM2852 refrigerator, check light. When on electric power the check light occasionally comes... (More)
Answer
freezer works but refrigerator stays around 50-55 degrees....dometic rm2852
Answer
I have a Dometic refigerator model RM 2852. I use it on elec and the drinks freeze and explode in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repairmen
in San Mateo, CA
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
