Question about Pool & Spa
Need a new tracking rail for a swimline pool the
Need a new tracking rail for a pool the one we have is rusted
You need to know the pool size, manufacturer, and model... They are ALL different. Go back to where you purchased it.
Posted on Sep 05, 2009
How do you hook up a hydrotool model #72712 to an above ground pool
in of pump to skimmer out of pump to intake of filter out of filter should be return or to pool that goes to pool return other hose is for backwash
May 25, 2016 | Swimline Hydrotools Sand Filter
How can we take it apart after we drained the pool?
Question:
How do I properly remove my above ground pool?
Answer: by Osko Pool n Spa Onground Pool Removal Guide
Recently, a reader of one of my other articles asked the question;
" How do you take down an above ground swimming pool to move it? I can't seem to find anything to help me. I read your article on replacing a liner but I need to know how to move the entire pool".
Well, (I thought to my self), this is a very good question. So, here is a basic step-by-step guide on the basic proceedure: ( You'll need at least three people, to help with your wall).
1) Drain all water out of pool using a sump pump.
2) Remove skimmers, returns, lights etc.
3) Remove old liner, (use a razor knife and cut into manageable folded pieces). You'll need a new liner if your going to reinstall the pool.
4) Remove Top Seat Ledge covers
5) Remove Top Seat Ledges.
6) Remove Top Rail and Joiner Plates.
7) Locate Wall Bolt Joint on the Pool Wall and remove the corresponding Upright.
8) Now, get some help and remove all Wall Bolts and associated hardware.
9) Next, start pulling the wall out of the bottom rail (track). And roll the wall up as you remove it from the bottom rail. When finished, duct tape the wall so it does not unroll.
10) Pull the uprights, bottom rail and bottom rail joiner plates out of the ground in sections.
11) Remove uprights from bottom joiner plates.
12) Make sure to separate all components and save all hardware!
That's it!
Hope this helps!
Apr 09, 2016 | Intex 32 x 16 x 52" Ultra Frame...
How do i connect the filter to an above ground intex pool?
skimmer hose to front of the pump top of the pump to the in of the filter the out of the filter to the return
Jul 09, 2014 | Swimline Hydrotools Sand Filter
Where is the switch on pump
www.sears.com/hydrotools-hydro-tools...s...
Jul 02, 2014 | Swimline Corp Swimline 71225 Above Ground...
Where to connect valves
Hook a temp hose up to it, put it in water and see which way it flows. The intake is then connected to the bottom output from the pool.
Apr 09, 2014 | Swimline Hydrotools Sand Filter
Bearing size swimline pump 0.75 Kw
don't bother replacing if bad bearing motor soon behind and the heat from the bearings pump will start to leak soon replace whole unit
Apr 28, 2013 | Swimline Pool & Spa
Replacing liner 18x33: forgot to unscrew pump from alum. frame while filling pool. is it safe to cut a **** in the liner to pull the plate through or would it be safer to take the foot rail and coping
I have never had to cut a hole in my pool liners when installing them. What kind of hole are you trying to cut - I am not sure what you mean by pulling the pump cover through? If you will provide further details about what you are trying to do, I can help you better.
May 24, 2009 | Swimline Liner Guard Floor Padding 33'...
Swimline unibeaded liner - Is this the same as a beaded liner
Beaded and Uni-bead are not the same.
A uni-bead liner is what is often called a J-hook, if you want to use it in a pool that uses a beaded liner you need to remove the bead receiver. A J-hook liner attaches right to the pool wall, not a bead receiver.
Mar 07, 2009 | Swimline 12 X 18ft Oval Beaded Caribbean...
Pool & Spa Logo
32 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
