Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Psi will not go above 40 psi tank presuure will not go above 20ps
I have replaced the check valve
  • larrdental Jun 27, 2009
    for davidpsr keeps running never gets to full pressure!!
  • David Mcintosh
    David Mcintosh May 11, 2010
    Does the compressor cycle off prematurely, or keep running yet never gets up to full pressure?
  • 508 Answers
Chech air filters for restrictions if not compressor internal parts worn!!!Good Luck to You!!!!
Posted on Jun 27, 2009
I am having the same problem with my craftsman 919-154010 And my problem is a broke flapper valve sad part is that they no longer make the replacement part i need pull the head off and you should see it. hope this helps.
Posted on Jul 03, 2009
F21 fault code on Electrolux dishwasher. What does it mean and how can i clear it??
Electrolux Dishwasher Error Code 01
Fault Condition: Water Leak Is Detected (Sensor under the dishwasher detected a leak)
Repair or Check: Remove power to the dishwasher. Check hoses, pumps, and tub to find the leak. Replace any parts leaking.
Parts Required: Drain Hose - Drain Pump - Recirculation Pump
Electrolux Dishwasher Error Code 02
Fault Condition: Thermistor Sensor Fail
Repair or Check: Remove power power to the dishwasher and check the thermistor sensor circuit wiring. If the wiring checks out then replace the thermistor sensor.
Parts Required: Thermistor Sensor
Electrolux Dishwasher Error Code 03
Fault Condition: Wash Motor Fail
Repair or Check: Remove power to the dishwasher. Inspect the wiring for the wash motor. If the wiring checks out then check for an blockage in the pump. Replace the wash motor if the pump is not blocked and the wiring checks out.
Parts Required: Wash Motor
Electrolux Dishwasher Error Code 04
Fault Condition: Upper Fan Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the upper fan. If the wiring checks out then replace the upper fan.
Parts Required: Upper Fan
Electrolux Dishwasher Error Code 05
Fault Condition: Upper Fan/Vent Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the upper fan vent. If the wiring checks out then replace the upper fan vent.
Parts Required: Upper Fan/Vent
Electrolux Dishwasher Error Code 06
Fault Condition: Lower Fan Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the lower fan. If the wiring checks out then replace the lower fan.
Parts Required: Lower Fan
Electrolux Dishwasher Error Code 07
Fault Condition: Drain Valve Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the drain valve. If the wiring checks out then replace the drain valve.
Parts Required: Drain Valve
Electrolux Dishwasher Error Code 08
Fault Condition: User Interface Control Fail
Repair or Check: A switch on the user interface is possibly defective. Replace the complete user interface.
Parts Required: User Interface Control
Electrolux Dishwasher Error Code 09
Fault Condition: Communication Fail From User Interface Control TO Electronic Control Board
Repair or Check: Remove power to the dishwasher and check for any loose wiring connections between the user interface control and the electronic control board. If the wires and connections check out then replace the user interface control. If the problem persists then replace the electronic control board.
Parts Required: User Interface Control - Electronic Control Board
Electrolux Dishwasher Error Code 10
Fault Condition: Electronic Control Board (Relay) Fail
Repair or Check: A relay on the electronic control board possibly failed. Replace the complete electronic control board.
Parts Required: Electronic Control Board
Electrolux Dishwasher Error Code 11
Electrolux Dishwasher Error Code 12
Fault Condition: Drain Valve Position (Drain valve has activated when it should be turned off)
Repair or Check: Remove power to the dishwasher. Check the drain valve wiring for an issue. If the wiring checks out then replace the electronic control board. (This is because the drain valve relay on the control board is stuck) If the problem persists then replace the drain valve.
Parts Required: Electronic Control Board - Drain Valve
Electrolux Dishwasher Error Code 13
Fault Condition: Electronic Control Board Fail
Repair or Check: The control board has a component failure. Replace the complete electronic control board.
Electrolux Dishwasher Error Code 30
Inconsistency between level on electronic pressure switch and level on anti boiling pressure switch.
Electrolux Dishwasher Error Code 50
Fault on the wash motor circuit. On some Electrolux dishwashers the motor has a control board located at the back at the bottom just behind the wash motor.
Jun 18, 2018 | Electrolux Dishwashers
Whirlpool duet 8E error code, what is the cause?
F8E0Steam valve failureCheck the water supply hoses for kinks. Check for a restricted screen in the water valves. Replace the steam valve if defective.
Steam valve
F8E1No water detectedMake sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it.
See the repair guide to fix it yourselfWater valve assembly
F8E2Dispenser failureThe dispenser can't move into position. Unplug the washer and check the mechanical linkage on the dispenser housing. Repair or replace any damaged dispenser parts.
Dispenser assembly parts
F8E3Overflow conditionUnplug the washer and, if the washer is overfilled, check the water valve assembly for proper shut-off of water flow. If the water valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water level pressure switch.
See the repair guide to fix it yourselfWater valve assembly, water level pressure switch
F8E4Low water flowThe flow meter detects a long fill time. Make sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it. If water flows normally, replace the flow meter.
See the repair guide to fix it yourselfWater valve assembly, flow meter
F9E1Long drainRemove excess suds; the washer can't drain excessively sudsy water. Check your house drain system for a clog. Check the drain hose for kinks or clogs. Replace the drain pump if defective. If the washer drains properly, replace the water level pressure switch because it isn't accurately detecting the water level.
See the repair guide to fix it yourselfDrain pump, water level pressure switch
Oct 16, 2016 | Whirlpool Washing Machines
How to replace exhaust gas recirculation valve
Betty, Check the attached EGR links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Exhaust Gas Recirculation Valve EGR Checking
Faulty EGR Valve Symptoms and EGR Valve Cleaning
EGR Valve Replacement Chevy Venture 3 4L Engine
Installing New EGR Valve
Mar 08, 2016 | 2003 Pontiac Aztek
Replaced viable but no water filling just clicking noises
DISCONNECT THE ELECTRICITY , DISMANTLE THE INLET WATER HOSE CHECK THE WATER COME OUT, CHECK THE VALVE STRAINER ,CHECK THE VOLT ON THE VALVE IF THERE IS , REPLACE THE VALVE
Apr 02, 2014 | Frigidaire ATF6000ES Front Load Washer
I have an older Carrier furnace type 58ss. The main burner will not ignite. Operating look ~ thermostat set @ 78 deg, switch furnace on, inducer fan running, pilot light clicks and ignites, inducer still...
power to gas valve ok .. Replace gas valve after checking gas valve coil for continuity/resistance... with valve removed ...and power to valve ... try blowing thru valve from supply side ... stuck valve.... replace...
Nov 01, 2013 | Heating & Cooling
Error code 52
51. (00110011) Phase 5 ECO - Recirculation Fault
The product has detected that it is losing water during recirculation.
Primary Source - Diverter Valve Wiring
Action - Check diverter valve harness is correctly fastened to diverter valve. Check flying lead
in motor controller, and connection to valve next to drain pump.
Secondary Source - Diverter Valve
Action - Check diverter valve resistance. If open circuit (nominal is 1500 ohms) replace
diverter valve. During recirculation, check that water is being recirculated back into the bowl,
and that no water is coming out of drain hose. If there is some water coming from the drain
hose, then the diverter valve could be faulty, or it could be jammed with a foreign object.
Replace diverter valve.
Tertiary Source - Motor Controller
Action - The diverter valve drive circuit may be at fault. If the primary and secondary checks
pass inspection then replace the Motor Controller.
52. (00110100) Phase 5 ECO - Recirculation Fault
See fault code 51.
Apr 02, 2013 | Fisher and Paykel GWL11 Top Load Washer
EGR valve is being cleaned due to "Check Engine"
CLEANING THE VALVE WILL NOT RESOLVE THE ISSUE, IT SHOULD BE REPLACED.
Dec 15, 2010 | 2002 Isuzu Trooper
What does fault code 51 mean?
Error code 51 usually means a faulty diverter valve. Try and run a wash cycle, and observe the drain hose. If water comes out, the diverter valve should be fine, if no water comes out you should take your diverter valve out and check for debris, or continue to read through the following possibilities of why your washing machine is acting up, and the actions to take.
1. Diverter valve
Action - Check diverter valve continuity. If open circuit, replace diverter valve.
2. Motor Controller Board (drive circuitry blown).
Action - Replace Motor Controller Board
3. Diverter valve harness/connectors.
Action - Replace wiring harness
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a ge washer wpsr3120w0aa that leaks water when rinsing
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
©2006 Publications International, Ltd.
If an inlet valve is faulty, check the water connection and the
valve screens. Try gently tapping the solenoids;
if this doesn't work, replace the inlet valve assembly.
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Troubleshooting Water Leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Aug 29, 2009 | Washing Machines
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
571 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
