Question about Sony Playstation 3 (PS3) Console
During initial setup, after we choose the HDMI option the screen goes black. Work fine connected to TV
  • 4 Answers
Are you using an HDMI cable? If not, your best option is to get one online, because they go for about $59-99 at retail stores.
If you are using an HDMI cable, be sure you are using a resolution compatible with your TV. In display options, when you choose HDMI, you should find a list of checkboxes with resolutions (420p, 720i, etc). Personally, my TV only works up to 1080i, because it doesn't have progressive scan (p). The PS3 may be trying to set it to 1080p which your TV can't handle. Try out different resolutions until it works.
Posted on Jun 27, 2009
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
Jul 06, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Systems setup
Hii,
Try this out:
Go to the display settings in the settings menu. Pick HDMI for your video output and follow the steps to set your screen resolution. When I accepted the video settings I was taken automatically to the audio settings options. If you’re not given this option just go to the set audio output settings and enter this screen. Pick the optical connection and follow the screens choosing the audio options that match your receiver. DD and DTS.
At this point you should have video to your TV through HDMI and audio to your receiver through the optical cable.
Goodluck,
please dont forget to rate me as fixya..
Jan 28, 2008 | Denon AVR-3801 Receiver
55 inch thorn when on smart TV the screen is purple the output mode is set on 480CVBS and the screen is purple when I choose 576CVBS The screen is black I can't seem to get the smart tv option back
If your screen is purple, this indicates that your HDMI cable has a poor connection. First, try reinserting the HDMI. Second, try replacing it. Also, try a different HDMI input.
Jun 06, 2016 | Televison & Video
No OSD menu on Panasonic ST50 plasma TV
My guess is that the OSD function can only be enabled directly at the Panasonic TV.
Nov 18, 2013 | Yamaha Audio Players & Recorders
I have a PS3 hooked up via hdmi. The screen goes black for 1 second then comes back during game play. It doesn't do this when hooked up through component connections. I replaced the hdmi cable and...
Ur tv is on 3D mode setup probally,i'm wright?Yes?Set the tv it back to 2D mode,should stop the tv delaying 1 sec. black out intervolt should stop happening.Because ur are not using a 3D PS3 machine ur are using an PS3 2D a normal system.
Aug 08, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
How do I hook up a playstation 3 to my mitsubishi medallion hd 1080
The best way to hook up is via the HDMI port. Connect a HDMI cable from the PS3's HDMI port the tv's HDMI port. As soon as you power the PS3 and tv on, you should see the initial setup screen.If it does not dispay press and hold the power button of the PS3 for about 5-10 seconds till you hear a couple of beeps and the initial setup screen. After that its just following on screen instrucions to choose your language, resolution(1080i for best quality), aspect ratio(16:9 works best for large screen tvs) etc., If there is some setting that you are unsure about as to what you should choose, let me know and I will help you with that.
Sai.
Apr 28, 2011 | Mitsubishi Televison & Video
Just bought a ps3 two weeks ago. Played games just fine and everything worked well. We watched a movie last night. Turned off the system and went to bed. The next morning we tried turning it on but it...
This may be a simple fix. Do you still have the original cable that came with it for the video OUT? Plug this back into your playstation and TV while leaving the HDMI cable connected.
check now both HDMI channels and AV/Composite options on your source selection this should give you the display,
Now what we need to do is setup your HDMI output again.
From the menu bar,
  • Go to settings
  • Display Settings
  • Video output settings
  • choose HDMI
if you have the choice to choose OK choose it. If your screen goes blank go through your HDMI channels again and if the Playstation screen is there then select OK,
Then you can remove the composite cable again
Jan 14, 2011 | Video Game Consoles & Games
Screen goes black
sounds like you're using an HDMI cable, and the cable is broken. That's exactly what happens when HDMI cables break, a few of those 0s and 1s don't make it to the TV every once and a while, and the TV goes black and the audio dies.
or
go to system update and choose online update. an optional ps3 firmware 3.01 fixes this issue
also, I had a similar situation a while back. Anytime I loaded any disk (game or movie) it would just go black and freeze. I had to do a system reset (where it reloads everything and you lose your data). You can back everything up before that and restore it once you are done. It has worked fine for nearly a year since then.
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Sony Playstation 3 (PS3) Console Logo
151 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
