Question about Acer Aspire 3000 Notebook
CD-ROM Not responding
CD-ROM works for a little while after I turn the computer on, but then it suddenly stops working, mostly in the middle of me copying something onto a CD, and the blank CD is stuck in the drive i.e. the drive will not open.
  • 2,961 Answers
You can get the disc out by inserting a pin in the small hole on the cd draw, but when this happens it means the laser is failing to read the disc and the cdrom is failing, unfortunately the cdrom cannot be changed in the acer notebooks.
Posted on Nov 06, 2007
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
My computer has suddenly stopped detecting the Samsung CD-RW/DVD-ROM Combo Drive. It does not display E: drive in the Windows explorer. I am not able to play any kind of discs.
Right–click My Computer, click Manage, and then click Device Manager. make sure there are no yellow or red boxes in the left. if it is rede or yellow, right click and update drivers. If this doesn't work, turn your computer off then unplug. Open the case and re-seat the cables. Plug system in, and turn on. If you can't see the drive still under my computer you will need a new drive.
Feb 03, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
I put the cd rom into the drive and nothing happens. I go to click on the icon under my computer and it causes the window not to respond.
Confirm that the CD drive is not a CD-ROM dive and the CD you are trying to open is is not a DVD. CD-ROM drive wil not open a DVD ROM and in some cases will cause the system to stop responding if youtry to run it.
Jan 26, 2010 | The Learning Company Oregon Trail 5th...
My cd rom keeps saying no disc and the computer
First thing to try is to clean the DVD lense. a lense cleaner can be purchased any from Best-Buy to Wal-Mart. It's essentially a CD with a built in brush. This will clean the lense.
if that doesn't work, it may be time to replace the drive. DVD-ROM drives can be purchased for as little as $20 now, it may be worth your time to just replace it. It is possible that the motor that spins the DVD has gone bad, but it is highly unlikely.
Jan 22, 2010 | Alienware PC Systems Alienware Aurora High...
Cd rom dvd burner stopped working
uninstall mcafee then try the fix at this link... if it works then reinstall mcafee and see if all is well... if it repeats then mcafee is the problem...
Jan 03, 2010 | Computers & Internet
The cd burner in my computer just stopped working
if nothing working try to uninstall the driver and reintall it and see if that work if not need to change it...go to device manager and delete the device and restart the computer and see if it will load new one.
Nov 08, 2009 | Dell HP Pavilion ZE5000 ZE4000 NX9000...
My dvd rw drive doesn't work anymore!
there is no problem with your driver but definitely you have a broken cd rom, you may need a cd rom replacement
Jul 02, 2009 | Acer Aspire 5920 AS5920 Notebook
How to do a system recovery when my cd rom drive doesnt work?
got to have a new cd-rom drive mate, most practical approach.
other options are network boot (done in offices with many computers), USB boot (if your BIOS supports it & you need to have a USB device with the bootable image of the system disk), etc.
Jan 26, 2009 | Computers & Internet
Cd rom has stopped working. the light is flashing as if it is working but the cd is not spinning.
Check the disk for scratches, and try other disks to make sure the problem is not unique to that one disk. If all disks fail, then double-click on My Computer, then double click on the CD-Rom drive and see if a CD will run. The "autorun" option may have been disabled, which is very noticeable if you've been used to this feature working. To re-enable autorun, right click on the cd-rom drive in My Computer, and go to device properties - recheck the autorun or autoplay option.
If none of the above resolve, then turn off your computer. Open up your computer with screwdriver. Unplug and replug the cd-rom driver. Restart computer. Test cd-rom drive again.
If it still fails, Make sure you are connected to the internet (I am assuming Windows XP - Vista may vary): Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> DVD/CD Rom Drives - se if the drive has a yellow exclamation by it - if it does, then right click on the yellow exclamation, and click install drivers - windows will most likely find a solution
If all of the above fails, write back with more details, including model/manufatcurer of cd-rom drive, and model/manufatcurer of computer.
Jun 11, 2008 | Computers & Internet
Sudden death of Dell Axim X30
Hello edil, This sounds like a corrupted ROM file. The ROM stores all your operating system and pda's firmware alltogheter. If it becomes severely corrupt the pda doesn't boot properly or doesn't work at all. This appears like a fixable problem however you will need to have it fixed in a service center, because they need to acces your device's bootloader or rewrite it using some special hardware, then they will rewrite the memory with a fresh rom file. This will have you device up and working. However please avoid to send it to dell as this will get expensive. Most pda services are able to do this and the generic ones will do it cheaper. Try to look for a cheaper, generic "pda service" center. Hope it helps.
Jun 04, 2007 | Dell Axim X30 Pocket PC
Acer Aspire 3000 Notebook Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
